Old 02-24-2011, 07:05 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Air loss in slicks
What is an acceptable amount (pounds) of air loss over a 24
hour period in a set of Goodyear radial 30/9/15 slicks that have
been coated (washed) with dish soap on the inside walls?
A few pounds (2-3)? None? More?
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 02-24-2011, 07:35 PM   #2
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Air loss in slicks
I run Hoosier radial 30/9/15, and get no air loss over a several day span...... I would think the Goodyears should do the same.....
Old 02-24-2011, 07:54 PM   #3
7423
Mickey 29.5 radials, no leak over ANY amount of time. Don't forget, 2 pieces wheels can leak bigtime..........................
7423 is offline   Reply With Quote
Old 02-24-2011, 07:57 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Air loss in slicks
There are a lot of variables between tires - compounds, construction techniques, etc.
When I bracket raced, I also "painted" the insides of the Phoenix tires I used back then with dishwashing soap because of varying air loss. Started with the Hoosier radials also in Stock but found out they didn't need it after I started getting them mounted at the races.
My 3-piece Holeshot wheels are silicone sealed from the manufacturer. But also check the metal valve stem seals and shraeder (spelling?) valves periodically.
Old 02-24-2011, 08:13 PM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
I run every brand of slick over the past 2 decades and Phoenix are the worst for leakage, on the rims in 2 days with M/T coming in second.
I never soap my sidewalls, don't have to cause I run Hoosier slicks
Hoosiers don't leak air!
Old 02-24-2011, 08:49 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,252 Times in 989 Posts
I have very little loss in my Hoosiers but dismount/mount can be hard on the sealant in 2 piece wheels that have aged some. Just spray some soapy water on the wheel itself to check for that.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-25-2011, 02:02 AM   #7
Philip Saran
Tomorrow or Saturday I will pull the wheels/slicks off the car (on
jack stands now) and dunk them in a large bucket of water.
The wheels are a used set of Weld 15/8 and they have holes in
the rims for screws, but I do not have screws in them.
Thanks for the input.
Phil Saran
Parker, Colorado
Old 02-25-2011, 09:44 AM   #8
terry1
Liked 24 Times in 13 Posts
Cool Re: Air loss in slicks
Is there anybody still using tubes?
terry1 is offline   Reply With Quote
Old 02-25-2011, 10:51 AM   #9
jasondearduff
every slick i have ever had and even the sticky street tires i have leak. i always figured it was because the screws?
jasondearduff is offline   Reply With Quote
Old 02-25-2011, 12:14 PM   #10
1320racer
1320racer's Avatar
no tubes and no rim screws here for 20 years.
