Old 01-30-2011, 03:50 PM   #1
John Lang
Liked 6 Times in 2 Posts
Smile Rear Gear Lube ?
Any ideas as to which Gear Lube, to run In a Stk Elim car ? It's a Dana 60, with a spool! It's also a heavy car C/SA, RR with 440 ! Thanks.......John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 01-30-2011, 04:22 PM   #2
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Rear Gear Lube ?
John,
You can't go wrong with any of the brand name Syn Lubes.. You only need to run one Qt. Hope this helps ....
Dave Ribeiro 1033 STK
Old 01-30-2011, 06:23 PM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Rear Gear Lube ?
What Dave said............. I like AMSOIL products........
Old 01-30-2011, 06:25 PM   #4
Chad Rhodes
I've always run the redline lightweight. However considering the luck I have had with the Joe Gibbs engine oil, I have just put their superspeedway/qualifying gear lube in the camaro
Chad Rhodes 2113 I/SA
Old 01-31-2011, 12:33 AM   #5
KingReptile
Redline 75-140 I have run shockproof too.Add a touch of Moly dont go any thinner there is no gain..
KingReptile is offline   Reply With Quote
Old 01-31-2011, 12:38 AM   #6
KingReptile
I would stay away from that lighweight oil,seen a few failures when i was at Jerico.There is no shock resistance with that oil,we also seen a lot of gear tips with raised tips.Chad trust me drain it,your asking for problems with it.The circle jerks warm there trans and rear ends before they make a lap..If u need names that can tell u there experience with it e-mail me krperformance1220@yahoo.com
Old 01-31-2011, 01:19 PM   #7
John Lang
Thumbs up Re: Rear Gear Lube ?
Dave and the rest, Thank You, and your sure about the ONE quart, in a Dana 60 ? If so I'll do it, Thanks a lot ,,,,,,,,,,,,,,,,John
