Old 01-27-2011, 07:55 PM   #1
Glenn Quinn
Glenn Quinn's Avatar
Default mirror for door cars
I am looking for a mirror for my door car, so I can see those dragsters coming. I was thinking about one of the wraparound panoramic wide angle ones from JC Whitney any suggestions on what works?
Thanks,
Glenn
Glenn Quinn is offline   Reply With Quote
Old 01-27-2011, 09:20 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: mirror for door cars
If you ain't at least matching the reaction time of the driver of that dragster in the other lane, won't matter what mirror you've got in your car most times.
Besides, you should have your head spun around like Linda Blair once you're in high gear watching that dragster's closing rate.
Old 01-27-2011, 10:44 PM   #3
Johnymia Racing
Johnymia Racing's Avatar
I agree with 1320. Get you RT right and knowing you dial in are the most important things. Most times, that gets you right even against the dragsters. I put a fair share of them on the trailers just working it that way. Top side games (knowledge ) is always good to know. I use the old stock rear view mirror in my Nova and it work just fine on closing rates. However in some door cars spinning your head around to get a good look is not always possible depending on how you are strapped in, helmut view, and obstructions ect. Do what is best for you. I know guys who just use a side spot mirror like the Nascar boys. Good luck, and don't be intimidated by them. Race your race.
Johnymia Racing is offline   Reply With Quote
Old 01-27-2011, 11:47 PM   #4
1320racer
1320racer's Avatar
wasn't using no mirrors here and never do!
Just put together packages like this against those pesky piperacks
and your lamp will come on most every time.
Old 01-28-2011, 12:34 PM   #5
Charlie Yannetti
Liked 192 Times in 83 Posts
Hey Glenn.. all kidding aside.. I drive and crew on some top Comp Eliminator teams, where mirrors are a necessity on the slower cars.. I would check out the mirrors that you can get through Biondo Racing Products.. they will hook you up..
Charlie Yannetti is offline   Reply With Quote
Old 01-29-2011, 10:41 PM   #6
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
The JC Whitney mirror is exactly the one Al Vanis used when he won the Englishtown national event in 2003, running in N/SA- in other words, almost always being chased.
A curved mirror definitely helps prevent losing a chaser in your blind spot, or taking too much stripe when the chaser isn't going to be close.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
