Old 01-25-2011, 08:21 PM   #1
FSA1673
Liked 12 Times in 6 Posts
Default Pontiac Oil Ring Tension
Need help on picking an oil tension ring. How low of tension oil ring should I use. Engine is a 1971 455 stocker with a 0.060 overbore.
Thanks
FSA1673 is offline   Reply With Quote
Old 01-25-2011, 09:10 PM   #2
Default Re: Pontiac Oil Ring Tension
Thanks
Call Kevin Studaker @ Total Seal.
He's a Pontiac guy .Tell him I sent you.
Old 01-26-2011, 03:03 AM   #3
rowdyboys31
I have a .040 455 Buick G/SA, I use a standard bore Expander with the .040 Rails to make my own low tension oil set. I buy a cheap cast ring set for the expander. I run a stock Moly 5/64 top ring, a Back cut 2nd ring ( appox. .070 removed I.D.) and the trick oil ring set(LOL). I also run a .060 350 K/SA that I tryed the Std. Expander in the .060 overbore an Oil control was a problem, Again 5/64 moly top ring, back cut 2nd an it was very low tension setup. Even with all the oil contamination the motor made good power it ran 1.17 under at the 2009 U.S. Nationals. I currently am freshing up the 350, I'm going to replace the std. Expander with a .020 over Expander for better oil control. JKeihn3954
rowdyboys31 is offline   Reply With Quote
Old 01-26-2011, 09:11 AM   #4
FSA1673
Thanks for the replies, it is much appreciated. Please keep them coming if anyone else has anymore suggestions for rings sets.
Scott Underhill
