Has anyone experienced firewall flex in a stick car and if so what is the recommended repair?
Liked 784 Times in 196 Posts
Moroso used to make a brace that bolted to the two bottom master cylinder bolts and extended to the subframe to help prevent firewall flex for the clutch pedal pivot. It's an old part (like me. Only I'm an old fart!), from the 70s. Is that what you are talking about?
Yes. I just emailed Moroso to see if they have anything like that. Thanks for the info. If they don't have anything I will have to fabricate it myself.
Liked 5 Times in 5 Posts
I've seen Chevy II racers make a brace that runs from the master cylinder to the top of the shock tower. Theres quite a bit of movement on those cars,,up to 1/2 an inch with the old heavy clutches we used to run back in the '70s,,,maybe its better with the modern clutches.
Danny Durham |
Liked 13 Times in 10 Posts
jimmy parker has a great working brace for this application pm him here
Liked 321 Times in 109 Posts
My guess is you have old 2800-3200 lbs. pressure plate? If so take it out get a good clutch setup that will fix your firewall flex and save every driveline piece in the car.
Mike Taylor 3601 |
