Old 06-05-2007, 10:31 AM   #1
ChevyII
ChevyII's Avatar
Liked 2 Times in 2 Posts
Default T-Stop Woes
Looking for some help with a new T-stop.
I am using a K&R Pro cube with a # 1 air stop and an air shifter triggered on time. Air bottle regulator is showing 90 lbs pressure and excellent volume.
Using Timer # 1 for stop and Time # 2 for shifter. I am not using Timer# 3.
Stop cycles in pits with motor not running but when I go to make a pass the stop will not activate.
Would like to get feedback from anyone using a K&R Pro cube or # 1 air stop.
Thanks,
Mike
ChevyII is offline   Reply With Quote
Old 06-05-2007, 11:51 AM   #2
crewchiefpro
Guest
Posts: n/a
Default
Thanks,
Mike
I would check to make sure there is power to the solinoid when the engine is running, if there is then I would call K&R.
Don Higgins
Crew Chief PRO Software and Weather Stations
www.crewchiefpro.com
Old 06-09-2007, 06:27 AM   #3
Bryan Gillespie
Banned
Default
I used a K&R box and the stop worked in the normaly off position,not the on position,try that
Bryan
s/g & s/p 120
s/st & s/c 1219
Bryan Gillespie is offline   Reply With Quote
Old 06-09-2007, 05:58 PM   #4
ChevyII
ChevyII's Avatar
Default
Hey guys thanks for the tips!
Gatsby the t-stop and the air shifter are being run in the OFF position. Appreciate the confirmation!
I think I have found the problem. The solenoid is not getting full power under normal running conditions as Don stated.
Appreciate all the help!
Mike
