Old 12-13-2010, 07:55 PM   #1
Shawn S.Kvaas
Default H,I,J,K,L,M,N,O,P,Q Firebird for Sale
Car started life as an original 1978-400" Trans am
Car is currently set up as a 1977 Formula Firebird
350" 4bbl pontiac motor,K/SA -.1.06 under the new index
Engine is .060" over Ross coated pistons,coated mains,and coated rod bearngs
Eagle H-beam rods on a 10-10 crank
SFI flexplate,SFI aluminum balancer
Fully prepped 6X-4 heads with ferra valves
Brand new Ashley Q jet,1 3/4" coated hooker super comp headers
T-350 trans with 2.75 low gear set
Turbo Action 1-2 automatic valve body
250 sun gear shell,reaction carrier,and output shaft
Brand new freshened TCS 8" converter
8.5" 10 bolt rear end modified by Alf Weibe
Brand new 4.56 ring and pinion
Moser spool and moser 33 spline axles with 5/8" wheel studs
Big ford bearing housing ends
Areomotive disk brakes up front,and oem set up in the rear
Car has a 5 gallon fuel cell and mallory 140 fuel pump
Car has a chromoly roll bar by Alf Weibe
Full interior and frame conectors
This 350"pontiac combo can run K/SA,L/SA,M/SA,N/SA
This package deal also comes with many,many spare parts and engines;
A 100% complete turn key 400" 6X-4 pontiac motor,legal for 1977-78' H/SA,I/SA,J/SA
This combo has run -.750 under the new index
Another 100% complete turn key 400" 6X-8 pontiac motor legal for 1976-77'-78'
This combo has run -.500 under the new index
If the car is run with its 1976 front end,that 400"6X-8 motor can run J/SA,K/SA,L/SA
If you install my 350" 4bbl for 76' you can run K/SA,L/SA,M/SA
If you put on my 2bbl set up you can run O/SA,P/SA,Q/SA
Also if you claim the car as a 1978 Firebird it can also run the Chevy 350"combo,Chevy 305"combo,and the Olds 403 combo
Some more spare motors and parts;
A complete 1977 350 pontiac motor 6X-4 heads
A complete 1977 350 pontiac motor 6X-8 heads
3 bare 350 blocks for core use
2 pairs bare 6X-4 heads,1 pair 6X-8 heads
1 pair #51 heads for a 1976 455 combo
10 intake manifolds for 76'-77'-78'
Various interior and trim peices
Brand new Comp Cam and pro magnum lifters in the box
Also complete 1976 nose and related parts to change over to a 1976 firebird
Spare std-std crank,for the 350 with coated bearings,and 2 spare coated pistons
Also extra 2.75 low gear set t-350 with Turbo Action 1-2 auto valve body
Spare 15"x8" weld wheels
Removable 3" exhaust,extra hooker headers
Extra stock t-350 that works good
Spare Ashley Q jet,and many more parts
Car is silver in color,see pics at autoimagery search Shawn Kvaas,David Rastad,Bill Edgeworth
Also have dyno sheets,chassis dyno sheet,and time slips
This car has won 4 division 6 open championships
Possible delivery
Reply to shawnskvaas@hotmail.com $22,000 USD
Shawn S.Kvaas is offline   Reply With Quote
Search this Thread:
Advanced Search
