Liked 6 Times in 4 Posts
I am doing some bracing on my GM "A" body rear suspension LCA mounting areas.
My question is.... What is your experience with using weldable primer and mig welding? Tell me if this works and what steps I need to take in the prep. of this operation? TIA...... |
Liked 557 Times in 217 Posts
I repair welding equipment. Have been doing this for 15 years. I test everything I repair especially mig machines......I have no experience with a "weldable primer" and never heard of it......but I know from experience....mig weldling "thru"any paint is difficult to get it started. You can clean one area and get the weld started and it burns off the paint in front of the weld. Mig and tig welding like clean material......
I am sure the product works but probaly not nearly as good as the manufacturer says.....My guess is it has conductive properties, meaning it does not insulate between the gun and the ground. It also probably has high metallic content and the paint burns off without contaminatiing the weld site Do a google search and go to any forum where pro welder/operators talk about things like this......I would bet they say they hate it and grind it off.....LOL
Liked 47 Times in 21 Posts
Bob, what you are looking for is a weld thru primer. SEMS brand is good. You can get it at any automotive paint store. Clean the weld areas to remove oils etc. Spray the primer in these areas and let it completely dry before you start welding.
http://www.google.com/products/catal...d=0CCIQ8wIwAA# |
There are many brands of weld thru primer, we use 'UPOL' copper rich ourselves. The weld thru primer is meant mostly for welding sheetmetal together, the primer melts and surrounds the weld or 'hot spot' to conceal the spot from potential rust issues. for welding the LCA areas clean the area thoroughly as it is not an ideal location as it will most likely be overhead and cramped quarters ,and undercoat or paint afterwards. The weld thru primer may cause a problem for striking an arc and will promote spattering of the weld. An alternative is to use POR15 afterward, that s**t is incredibly tough and will glue the lid to the can if your sloppy with it haha, hope this helps
Dion Hildebrandt 6009 STK H/SA |
Liked 20 Times in 3 Posts
Actually you shouldnt even need a weldable primer in that location, just clean it good and weld it. Primer it after. You will get a much better weld, and if its a racecar you shouldnt have rust issues there anyway if painted properly. I do alot of racecar fabrication, mostly tig, but never use a weldable primer.
I 've used that stuff on floorboard patches,etc at the overlap ,where it does work well.
It'll kinda melt away from the tack weld ,but still have a coating in place when you're done. I agree with others...You really don't need it for chassis work.
