Old 08-30-2010, 09:12 PM   #1
one pontiac
Default considering class a rv for towing
considering class a used rv. budget dictates older 1985-1992, 26-35 ft, probably 454/460 gas. can this size pull a 24ft enclosed trailer and is it possible to get a suitable hitch? all comments are welcome, thank you.
one pontiac is offline   Reply With Quote
Old 08-30-2010, 09:52 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Smile Re: considering class a rv for towing
E-mail me your email address, and I will tell you about my Class A experiences ! ss3011@aol.com
Old 08-30-2010, 10:12 PM   #3
Talking Re: considering class a rv for towing
Sent you a PM ...........................
Old 08-30-2010, 11:18 PM   #4
JWhalen58
Liked 117 Times in 21 Posts
Default Re: considering class a rv for towing
I have a 1994 SeaBreeze 31ft, 454, clean everything works, we have used it to tow to about 10 events, it handles our 28ft trailer very well, I am looking to sell it and move up to a bigger unit, $9900 if you have any interest, I would go out right now and go anywhere in it. Jim
JWhalen58 is offline   Reply With Quote
Old 08-31-2010, 08:36 AM   #5
SCOTT SST2871
I have a 35ft bounder gm chassis, i pull a 28 ft classic dominator with a golf cart drum of fuel large tool box and a 3000 lb car..ive braced the rear frame and braced the hitch with 2x2 boxed tubing!!its got about 15000 miles since i got it no problem
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 08-31-2010, 08:38 AM   #6
SCOTT SST2871
If you get a 26-27ft gm chassis you wont need to do any frame work but you will need a better hitch,trust me been there!!
Scott fifield
Old 08-31-2010, 08:44 AM   #7
danny waters sr
danny waters sr's Avatar
Thumbs up Re: considering class a rv for towing
I got a 98 Dolphin 34ft with a slide-out .It has a 460 Ford engine. It pulls 26 and 28 ft trailer with no problem. I would invest in a tuff-tow or a trailer toad to help support the rear half of your motorhome. I love mine (ours) and my wife loves me .lol
Old 08-31-2010, 08:51 AM   #8
Dave Casey
Liked 804 Times in 168 Posts
You will be fine, I have over over 150,000 miles of towing between 2 diff motorhomes with an enclosed 24' trailer.
my suggestions are
travel as lightly as possible, don't take stuff you don't need
Get the shortest motorhome with the longest wheelbase you can find
Look at the motorhome construction, especially the frame behind the axle
Pay the most attention to the tires and the transmission in the motorhome, they are the things that will give the most trouble on the road. Check tire pressures every trip and service the trans regularly
Ask questions here if you see a coach you are considering.
Dave Casey 1330 STK
Old 08-31-2010, 08:52 AM   #9
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
If you're going to do it on a modest budget, research carefully. .............Forget anything with a GM chassis, Not strong enough,even after reinforcing, altho mabe with a trailer toad .....I had a 26' class A coach with a 460 gas motor and an Oshkosh chassis that handled my 26' Goldrush effortlessly and is still in use by another racer..............HOWEVER, stay away from the carbureted Ford 460 engine!...They have a mad appitite for cylinder heads. .....I replaced at least 4 sets of heads in the 70k miles I towed with it !..................The ex valve seats are too soft to handle the heat generated by towing loads. ....Even heads with hardened seats wont last long, as the hard seat just receedes into the soft cast iron!..............Dont jump at just anything, nobody is standing in line to buy a Coach right now any way...............Tom
Old 08-31-2010, 02:05 PM   #10
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Are there any common problems with the fuel injected 460. I just bought an 88 E350 cube van for towing my open trailer. How bad are these on mileage. The guy said he could get 7-8 mpg towing ride and game trailers used in carnivals and fairs and a little over 10 when not towing, I'll believe that when I see it, Paul.
