Old 08-24-2010, 11:16 AM   #1
THE LEGEND
Default t stop thoughts/debate
Shut down more with less time
or
Shut down less with more time.
Chip
THE LEGEND is offline   Reply With Quote
Old 08-24-2010, 11:33 AM   #2
Bill Baer
Default Re: t stop thoughts/debate
I would think it's a matter of preference, either will work but the less time on the stop the more MPH you'll carry at the stripe.
Old 08-24-2010, 03:11 PM   #3
JJ3159
JJ3159's Avatar
i like more shut down less time ,i try to find that spot that works for 9.90 and 10.90
jj h/r 1399 s/r 1399 s/g 1399
JJ3159 is offline   Reply With Quote
Old 08-24-2010, 03:32 PM   #4
THE LEGEND
I understand about the MPH thing. I'm looking for effeciency. I know when the blade are shut it affects air flow. If you change the rate or amount of air flow it's got to change the consistentcy/effeciency of the car so:
1) Do you have more air flow for a longer period
or
2) Less air flow for a shorter period
Old 08-24-2010, 04:07 PM   #5
sc7667
When starting out I was told and tried to set up the stop RPM so that you have a 2 to 2.5:1 ratio. even the stop manufacturers recommend this. I have had cars that it is 4000rpm and cars that that is closer to 5,000. I was told by Sherman Adcock once that you never want to go below 4000. I think it is because the convertor makes the car inconsistant.
Roy
sc7667 is offline   Reply With Quote
Old 08-24-2010, 06:36 PM   #6
Bill Baer
Roy
I too have heard that and believe it's true.
Previously I tried to go back to near idle so my F.I. barrell valve would close but it wasn't consistent so some time ago I started to take it down to ~4500 and I found that to be much more consistent.
The type of stop you use can make a difference also, if you get too low rpm with a blade type of stop it possible to get a lean stumble when it opens because you won't get an accelerator pump shot. Which of course is not a problem with an in line type stop.
Old 08-25-2010, 10:45 AM   #7
Barney B
Barney B's Avatar
Talking Re: t stop thoughts/debate
Roy
Told by who?
Barney B is offline   Reply With Quote
Old 08-25-2010, 12:59 PM   #8
TS310C
Roy
I guarantee there are several (myself included) high HP guys that have to have the stop set below 4000 RPM. I would have 5 secs of stop in some situations at that high of an RPM.
Ryan Koener
S/G 310C
TS310C is offline   Reply With Quote
