Old 06-30-2010, 09:08 AM   #1
FED 387
Liked 332 Times in 180 Posts
Question ??? regarding 1050 holley dominator carbs
If a Holley 1050 carb is/has been calibrated for use with alcohol and ya want to convert it over to be used with GAS---what needs to be changed other than jets??? or vice versa gas to alcohol---- anybody know for sure no guesses here please--thanx Comp 387
Old 06-30-2010, 09:50 AM   #2
Liked 1,822 Times in 413 Posts
Default Re: ??? regarding 1050 holley dominator carbs
Given what it takes to convert a gas carb to alcohol, it's a lot more than jets, and I'm not sure you can reverse the process, I've never tried. There are all sorts of restrictions you drill out to go to alcohol, you'd have to close them back up. It'd take a 1/2 hour or more to detail it here.
Old 06-30-2010, 10:00 AM   #3
SSDiv6
Liked 1,583 Times in 582 Posts
They are two different beasts: for starters, metering blocks are different and need to be changed. Inlet valves and bowl are different. Bleed orifices are also different.
Old 06-30-2010, 01:37 PM   #4
FED 387
Thanx for the replies---did not want to get totally involved in going that route either---had a chance to pick a few basket cases cheap just do not want the hassle of trying to make one work--thanx Comp 387
Old 06-30-2010, 06:17 PM   #5
Thurston
Thurston's Avatar
I have a 1050 Pro System Alochol Dominator I'll sell you. It has about 70 pass, most of which were 1/8 mile. Looks and works like new. New ones go for $1,100.00 let this one go for $750.00
Jim Thurston
616-399-2069
r-thurston@sbcglobal.net
Thurston is offline   Reply With Quote
Old 07-09-2010, 06:29 PM   #6
jmarkaudio
Boosters and booster pins, and both metering blocks. How cheap?
jmarkaudio is offline   Reply With Quote
