Old 12-31-2009, 01:01 AM   #1
Jeff Lee
Jeff Lee's Avatar
Default Check out my 427 Side Oiler barn find!
This is a complete 1967 Ford 427 / 425 HP side oiler. It's in a boat built in the mid 1960's. It's like a big fishing boat, not a drag or ski boat. The boat is falling apart due to rot. This is in a 1 acre storage yard I have listed for sale in Phoenix. I just got done taking down casting numbers and it's all 1967. It's supposed to be a Hollman - Moody built with a bigger marine cam. Who knows if that's true. The 83 year old owner knows what it is....
I believe I have it sold pending further tear down inspection.
Intake is C7AE-9425-A....can't find a "-A" online...what is that?
Heads are C6AE-F
Carbs are C5AF-9510-80...rear is List 3300 dated 751....front carb list is 3301 dated 752. Autolite tags are intact and mint on both carbs.
Ford DP distributor.
Cross-bolted block with screw-in freeze plugs.
What's the core value on this?
Jeff Lee 7494 D/S '70 AMX
Old 12-31-2009, 02:02 AM   #2
Jeff Cockream
Talking Re: Check out my 427 Side Oiler barn find!
Hey Jeff--That would look real good sitting in my Fairlane!!!
Jeff Cockream is offline   Reply With Quote
Old 12-31-2009, 02:36 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Check out my 427 Side Oiler barn find!
It isn't original... ;~)
It's been worked on...
Look at those carbs real close.
It has had Jiffy Kit carb kits installed.
What a find.
Adger Smith (Former SS)
Old 12-31-2009, 09:59 AM   #4
sammy christian
quite a few big cruisers used the 427. did a rebuild ( 1968 Chris Craft 30')for a customer 10 years ago and had to have a cracked block repaired simply because everyone knows you can't buy a replacement for less than $3-4K if you can even find one!
sammy christian is offline   Reply With Quote
Old 12-31-2009, 08:12 PM   #5
KMachine
What a find.
or it could be a borg warner carb kit
KMachine is offline   Reply With Quote
Old 12-31-2009, 08:25 PM   #6
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
and they like to strip out the float bowls too.
406's had cross bolted mains but i don't know about the screw in plugs....
Old 12-31-2009, 09:37 PM   #7
Jeff Lee
Jeff Lee's Avatar
Oh, I see what your talking about on the needle and seat. That's like what NAPA sells. I thought it was a wrong bowl issue.
I like these shoes. Waiting for my old "wafflle stompers" to come back.
I sure hope this isn't a reverse rotation engine!
Old 01-01-2010, 01:56 PM   #8
BlueOval Ralph
Banned
Only very late 406's as I remember never used in production (not even early 63 406's before Dec 1963 only for NASCAR.
BlueOval Ralph is offline   Reply With Quote
Old 12-31-2009, 10:32 AM   #9
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
True sweetness .... good for you....good thing someone who knew what it was saw if before the family had it hauled to the scrap yard....
Makes me sick every time I go down there, I got an uncut set of 426 Max Wedge heads there I can tell you Johhny and Jane wouldnt have thrown grandpas junk out if they knew what it was worth....
Did you have to buy the whole boat ?
Chris "drooze" Wertman is offline   Reply With Quote
Old 12-31-2009, 10:40 AM   #10
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Your # dose not show up on ford list but this one dose, carbs would be 750cfm, looks like a Med-Riser.
C7OE-9425-A
427
Certified65-69 406 427 428 HyPerf Ford Aftermarket -Drag only
2 X 4V Tunnel Port
Aluminum
Single Plane
Ports 2.05" x 2.20"
Ford Service Part Number ID C7OE-9424-A
Bob Pagano A/SA
