Liked 5 Times in 4 Posts
Now posted on Lucas site
Oh well (note sig change from AA/SA to A/SA), it effects everyone the same. Unless you can't run .3 under
Chad Rhodes 2113 I/SA |
can you post the link someone thanks
Sean Ward NHRA s/ss/comp#2882 SW4 MOTORSPORTS |
Liked 13 Times in 4 Posts
Joe Schaechter 3168 STK |
Liked 55 Times in 14 Posts
The AHFS will impact very few combinations with the new indexs. The HP committees job just got alot easier.
The new Mustangs and Mopars will most likely never see an adjustment. The proper way to adjust horsepower ratings is to take the average under the index runs of each car/engine combination and average them against each other. Example: car/engine average for combination X = .95 under index car/engine average for combination Y = .75 under index The HP needs to be adjusted for up (raised) for combination X or lowered (decreased) for combination Y. They aren't reinventing the wheel or performing brain surgery here. Last edited by fredjohnston; 12-18-2009 at 03:31 PM. |
Liked 13 Times in 9 Posts
Or they could've just moved the trigger up .15, which is primarily what they've done. It just won't LOOK like a -1.55 under run on paper next time.
Liked 499 Times in 91 Posts
NHRA could have approached the indexes a different way. They could've just made a valve spring pressure rule that would slow everyone up. Make it so that the pressure can't exceed 150 lbs on the seat. But NHRA doesn't want to work for their membership money which means testing pressures of the valve springs.
Casey Miles 248H (Exceptionally/Slow) |
WOW!! Now I can run all out and not worry about getting too far up the qualifing sheet. LOL!!!
Liked 633 Times in 88 Posts
What about class winners do they still need to run -.50 under to win class?
Charley Downing 3548 STK |
Liked 900 Times in 191 Posts
