Old 11-25-2009, 01:36 PM   #1
BobUnkefer
BobUnkefer's Avatar
Default Should be easy ? to get answer to
I would think there are numerous out there that know this,,,,,,
What is the weight difference between a small block/glide and a big block/turbo?
Think 68 Camaro application here.
100#?
125#?
more?
less?
Thanks,
Unk
BobUnkefer is offline   Reply With Quote
Old 11-25-2009, 01:52 PM   #2
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
Default Re: Should be easy ? to get answer to
Will the Rat be wearing alum heads ?
Old 11-25-2009, 01:58 PM   #3
BobUnkefer
BobUnkefer's Avatar
Steel headed Rat
Old 11-25-2009, 02:24 PM   #4
FED 387
Liked 336 Times in 183 Posts
Red face Re: Should be easy ? to get answer to
Bob----
Approx weights in Pounds
Engines:
steel head/intake SBC --575
steel head/intake BBC-- 685
Transmissions:
PG--95
Turbo 350--125
Turbo 400--195
TRANS WEIGHTS LESS CONVERTOR & FLUIDS-- ADD APPROX 25-30 LBS FOR CONV.--ADD 2 POUNDS PER QT TRANS FLUID
these are just ball park figures a lot depends on if you have trick or lightened parts in trans --small convertor(7/8in)---deep or stock pans---shorty or regular length tail case etc. Hope this helps -Comp 387
Old 11-25-2009, 02:27 PM   #5
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Approx. 226 lbs difference between a 396/325 HP 1968 Camaro with a 400 turbo and a 1968 350 Camaro with a P/G. The weight difference would of course be less if you ran a 350 Turbo or a 200 metric behind the 396.
Old 11-25-2009, 02:27 PM   #6
Tim H
Tim H's Avatar
That TH400 weight of 195lbs seems high?
I believe there to be approx. 30 lbs difference between the glide @ 95 lbs and the Th400 @ 125 lbs.
Old 11-25-2009, 02:36 PM   #7
BobUnkefer
BobUnkefer's Avatar
I knew you all would have the answer, now another question, how much weight is saved with a metric over a turbo?
I know, just full of questions,,,,,
but the answers are appreciated
Unk
