Old 11-15-2009, 10:30 PM   #1
Bob Alberty Jr.
Default B&M Trans Fluid Consistanct System
I have two New In the Box's B&M 70355 Transmission Fluid Consistency Systems
Keeps converter & trans running cool & consistent.
Ideal for drag racing applications where ET consistency is critical.
4 quart capacity.
Mounts virtually anywhere.
B&M’s Transmission Fluid Consistency System brings key performance benefits that every serious racer demands. Also recommended
for heavy duty use and towing applications to
increase fluid capacity in the transmission and converter circuit for cooler operation. The TFC System incorporates Radial Heat Dissipation technology, providing an additional 492 square inches of surface area, displacing heat faster between rounds, insuring consistent runs. This system gives you the benefit of under-mount inlet and outlet ports, allowing for cleaner installation and no fitting interference at the tires. Additionally, it comes with a machined top filler port for quick filling of ATF and a bottom
temperature port that works with all Autometer fittings, along with angle-adjust installation, so you can properly mount your system for perfect flow and performance.
B&M sells for $253.31 http://www.bmracing.com/PRODUCTS/Coo...istency-System
Jegs sells for $241.99 http://www.jegs.com/i/B%26amp%3BM/130/70355/10002/-1
Will take $200.00 apiece for these,
918-407-1718
Bob Alberty Jr. is offline   Reply With Quote
Search this Thread:
Advanced Search
