Old 09-07-2009, 06:42 AM   #1
terry1
Liked 24 Times in 13 Posts
Question Cylinder head question,again.
In stock eliminator,if your intake/exhaust runner volume(s)is to large,according to spec,do you have any recourse to reduce the volume?Or does the head go to the scrap heap?
Second;is there a tolerance in the volume numbers,0.1%,1.0%.no %
terry1 is offline   Reply With Quote
Old 09-07-2009, 06:44 AM   #2
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Default Re: Cylinder head question,again.
Scrap, door stop.
No tolerance if over
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 09-07-2009, 06:50 AM   #3
Liked 1,952 Times in 439 Posts
Depending on the valve you have in it, it may be possible to reduce the volume slightly by changing valves, although it will likely hurt performance. It might require a custom valve.
Old 09-07-2009, 06:54 AM   #4
Terry Cain
Terry Cain's Avatar
Also, it's possible to cut intake or exhaust side of head or intake to make it a little smaller. NOT much room to work with here though.
Terry Cain ???? STK
Old 09-07-2009, 11:06 AM   #5
Jody Lang
Liked 92 Times in 29 Posts
I should start a new thread for this, but I'll start here. There's a problem in the specs for the Stockers. I personally know of 4 people that have checked their runners and all 4 have been big on the exhaust. These are various Chev motors. In 3 of these it's only been 1 of the heads that's been big.
These are not acid heads either. The specs were for the Super Stock heads. Those that could braze/epoxy in the ports to get the desired CC's.
The new rule is affecting innocent racers that just assume their ports are ok because they're stock.
Jody Lang is offline   Reply With Quote
Old 09-07-2009, 02:46 PM   #6
Jeff Lee
Jeff Lee's Avatar
You can reduce the runner volumes by cutting the intake or exhaust surfaces as mentioned. Rule says you can not go past the valve cover bolt hoe.
You can also reduce those volumes by sinking the valve(s) deeper in the pocket. With some valve jobs you can gain flow by doing this correctly. Key word is correctly.
If it was a particularly rare head I would look at all avenues. If it's your dime-a-dozen head I'd scrape it.
And no, there is no tolerance on the plus side.
Jeff Lee 7494 D/S '70 AMX
