Old 08-23-2009, 02:41 PM   #1
RussellinNC
Thumbs up 67 Camaro RS & 67 Pontiac Firebird in North Carolina
Instead of making several ads Im just makin one so as not to break any forum rules about spaming,etc.
1967 Camaro Real RS,Future Stocker?.(Last raced with the Classic Gear Jammers) Clear title,No Engine or trans,(Had a small block and Jerico 4-speed) 4 wheel disc WILWOOD brakes,Braided Brake lines,Stock width 12-bolt rear with moser axles,spool,4:88 Pro Gear,Braced Aluminum rear end cover,Calvert Rear Split leaf springs and Cal-Trac bars,Frame connectors,Dual holly blue pumps, FRAM filter for each pump,fuel cell,Braided fuel lines front to rear,MSD ignition,Full factory interior with 6 point roll bar,GM cowl hood (I dont have a flat hood for stocker),Small block headers,1 chamber flowmasters,pipes and H pipe,Driveshaft,Rally Wheels,AutoMeter Gauges,Monster tach with Large pro shift light,Etc Etc...Drop in a small block and 4-speed and go play
I have the original Gas tank,Heater box,Heater controls,etc
$10000 FIRM on the Camaro...Possible trades?
67 Pontiac Firebird Drag Car, NOT Narrowed,No engine or trans,57 Pontiac rear,Spool,Slapper bars,New 4:10 gear,Weld Wheels,Full cage,Window net,fiberglass front fenders,Hood and bumper,New Lexan MARGUARD windshield,Has clutch pedal if you wanna run a stick,New 90/10 front shocks,solid subframe bushings,frame connectors,quick release steering wheel,Dual Line Locks,No title $5800 obo for the Firebird. You could make this into a Camaro if thats what ya wanted very easy
Ponattack1@aol.com for pics
704-682-3057
Statesville,NC
RussellinNC is offline   Reply With Quote
Search this Thread:
Advanced Search
