Old 05-30-2009, 01:04 PM   #1
treessavoy
Liked 4 Times in 4 Posts
Default Motor Home Towing
Not sure if this belongs here or not....feel free to move it.
I have a '36 motor home with the triton V10 and a '28 enclosed trailer with a 3600 car. Some of the Ford dealers have told me that the transmission won't last long if I tow my rig with it others said it would.
Does anyone tow with the Triton V10 and whatever trans that comes with it? I'm pretty much stuck with this motor home thanks to the divorce judge and I'd like to get some use out of it before it becomes a flower pot!
Help!
Old 05-30-2009, 01:29 PM   #2
Philip Saran
Liked 14 Times in 11 Posts
Default Re: Motor Home Towing
I don't have experience with the V10/auto, I have a 6.0 diesel/auto that I use
to tow both my travel trailer and open car trailer. I use the tow mode on shifter.
But be sure you have the hitch checked and beefed if needed for towing your
28 ft trailer. Also make sure you have a decent size trans cooler installed.
If you use the tow mode and run at a conservative speed, I don't see why you
would have any problems. But that means towing at 55-65 mph NOT 75-80.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 05-30-2009, 01:35 PM   #3
John DiBartolomeo
We've done hitch work on numerous motorhomes with that type of motor and I don't hear anyone complaining of trans problem. I think as long as you follow typical maintenance you shouldn't have a problem. I certainly wouldn't be afraid of towing with the unit. You might want to add a trans temperature gauge but I really don't think you're going to notice anything strange.
John DiBartolomeo
DRC Race Products
DragRacingActionOnline.com
Old 05-30-2009, 01:47 PM   #4
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
the thing that will help that unit is a trans cooler ,it may have a factory one on it but, put the biggest one you can fit on it and by pass the radiator you don t need the engine temp to build any heat,unless you towing in sub zero temps you dont need it,you should be ok,amd like mentioned trans temp gauge is key gmonde
Old 05-30-2009, 07:53 PM   #5
T Hall
T Hall's Avatar
My dad has one that he pulls a 28 ft trailer with. Has been fo about 6 years, Never a problem. The triton v10 lacks on power, so he added the Banks system, and it made a HUGE difference, as far as tranny, no probs.
Tony Hall
3545 S/ST
T Hall is offline   Reply With Quote
