I'm hoping someone on here can help me answer some questions. I have a set of aluminum cylinder heads I bought many years ago, finally went to use them and the pistons don't have enough clearance with the chambers. I initially thought that they must be closed chamber instead of open chamber, but the info I've found so far indicates that they are open chamber.
The castings are #3946074, date codes 11 14 73 & 7-10-74. I'm wondering if they have been surfaced significantly. Are there any standard measuring points to check for how much heads have been surfaced? Would it work to use thick copper head gaskets to get the clearance I need? I also noticed that they have more of a "D" shaped exhaust port. Is this typical for this vintage of castings? The photos of the "D" shaped ports I could find online also showed a ridge in the port floor, but mine do not have that. These have the holes for 2 extra head studs, apparently for aluminum blocks, but have been plugged with pipe plugs. Photos below: ![]() ![]() ![]() ![]() ![]() ![]() Regards,
Michael Pliska 643 S/G Last edited by Michael Pliska; 05-30-2009 at 11:23 AM. |
Liked 46 Times in 29 Posts
they appear from pics to be angle milled quite a bit by looking at the accessory bolt holes. intake valve is a bit out of chamber looking too.
Thanks, I was wondering of those two end bolt holes are normally the same distance from the deck surface.
The intake valves do protrude about 0.030" past the deck surface.
Michael Pliska 643 S/G |
Liked 336 Times in 183 Posts
that head is for a 69-71 Chevy 396/454 ---- 219 In /188 Ex ---118 CC chamber--- L-88/ZL-1/LS-6 with Rectangular intake port
Assuming the two accessory bolt holes were originally the same distance from the deck, it looks like they have had an angle cut equal to 0.86° (the holes are 6.72" apart, and the exhaust side one is 0.101" closer to the deck surface). Is this a typical angle cut?
Thanks,
Liked 2 Times in 1 Post
Sell those to a restoration guy. Buy a new set of "401" heads. You'll probably come out $$$ ahead.
Liked 16 Times in 11 Posts
Dont waste your time on old tech.........use the new heads like Ed said
Bob Pagano A/SA |
