Old 05-26-2009, 09:32 AM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Question PCV, advantage or not?
Is there an advantage, disadvantage or does it make no difference in leaving the PCV valve connected on a stocker?
Does it provide more air to the engine?
Or, should you just block the PCV port in the intake and forget about it?
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 05-26-2009, 12:21 PM   #2
mike natoli
mike natoli's Avatar
Liked 51 Times in 16 Posts
Default Re: PCV, advantage or not?
a pcv working properly will be closed under wide open throttle
mike natoli is offline   Reply With Quote
Old 05-26-2009, 02:12 PM   #3
Chris Hill
Liked 244 Times in 26 Posts
I've seen fast stockers both ways.
Chris Hill
Old 05-26-2009, 02:31 PM   #4
Dragsinger
Liked 99 Times in 60 Posts
I have run them both ways and as mentioned above, they are closed at wide open so no difference in performance. However, I think you will see less valve cover "milk" with a PCV. [maybe]
Usually I do not run a PCV but see no problem with doing so.
Larry Woodfin 471W
Old 05-26-2009, 05:54 PM   #5
Chris1529
Liked 70 Times in 29 Posts
I have a pcv valve on mine.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 05-26-2009, 07:45 PM   #6
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
i run two,and the engine is sealed good ,no dip stick or breathers,havent had a data to say weather if theres a horse power gain gmonde
