Old 03-25-2009, 08:52 PM   #1
Jack McCarthy
Liked 511 Times in 122 Posts
Default 3 speed for captain jack
well it wasnt the free ET i had planned on !
i have installed a turbo 350, 2.75 low gear with good insides, prepared by thomas arnett
it is a good piece using a powerglide input and my old converter
HOWEVER much to my amazement i was unable to ID anywhere on the track i made substantial gains..
the -1.15 was a good pass but not my best ever, however i offer these observations
1. i ran a glide for 28 years, and i knew what it wanted as far as gear, shift points etc.
.... the turbo was as fast as the powerglide on day one... room to improve
2. i believe i am over geared and will try the 5.86 instead of the 6.14 soonest
3. converter dropped flash from 4800-4900 to 4500-4600 i need looser converter
i believe there is ET there for me to obtain, however ill never beat that caddy
thanks to those whose interest has made this fun
jack mccarthy
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 03-25-2009, 09:08 PM   #2
bill dedman
Liked 6 Times in 4 Posts
Default Re: 3 speed for captain jack
Jack,
Thanks for the rundown!
I am curious as to the 60-foot times.
Were they better, the same, or worse?
Did you experience any wheelspin (that is NOT a trick question) with this new setup?
Thanks for the info!!!!
Bill
Bill
bill dedman is offline   Reply With Quote
Old 03-25-2009, 09:26 PM   #3
Jack McCarthy
60 foot might have improved .01 / .02 ?
i never spin, 2800 lbs rear 1700 lbs front
jack
"the Captain"
Old 03-25-2009, 10:08 PM   #4
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: 3 speed for captain jack
Hey Jack,
I would try that 5.86 gear before I changed the converter.
That should change the flash rpm in itself.
But I'm sure you knew that.
Good Luck!
Jim Cimarolli is offline   Reply With Quote
