I am going to be running F/SA with a 340 mopar. I would like to here what some guys run for alternators. Good/Bad, cost effective and high dollar. Are there any tricks with belts or pulleys, etc?
Liked 886 Times in 238 Posts
I use the East Coast auto electric Ultra mini 55 amp alternator on almost all the cars I build.....I've had one on one of my cars for 7 years with no problems. ..... It fits almost anywhere,and it has an ignition activation option that allows it to be turned off when desired {like a heads up run} . ....John and Chuck are good guys to deal with. .....Tom
I have a Power Master #8172 on my 340 Duster, it comes with a V pulley and has a built in regulator so it can be set up as a one wire. Just follow the directions and take the old Mopar voltage regulator out. I used some of the factory brackets and made up some spacers to get it lined up right, found the right length belt and it works great. In '05 it cost $175 from Summit, may be more now. It was 6lbs lighter than a stock one and it can handle the 7000 engine rpm it see's and it seems to charge good at low rpm's.
Liked 37 Times in 11 Posts
East coast all the way!!!!!!
Bill Kennedy 1671 SS |
