- Ex Brad Zaskowski comp eliminator motor
- Motor has only dyno time on it since being freshened by Gary Zimmerman at Zimmerman Bros. Speed Shop in Indiana. Dyno sheet available upon request. Makes enough power to run 1 second under NHRA index. - 302 cu. inch. - bowtie block - new $2500 kings crank - 55mm cam - patterson pistons - new GRP rods - jesel lifters, belt, rockers - PSI valve springs - 15 degree heads originally by CFE updated by Lump induction - sheet metal intake by CFE updated by lump has top for single or dual carb - csr water pump - moroso vacuum pump - stock car products external oil pump -msd crank trigger - pair 660 chuck gulledge carbs updated by book this past spring - moroso oil pan - dre engine diaper - kromer craft headers - two extra sets of rods, one set would not fit this motor (BME), others only have dyno time on them (MGP) Tranny: - Turbo 350 built by kenny shawver, no passes, built specifically for modified I will take $15,000 for the motor and $2,800 for the transmission however motor must go first. Thanks, Brian Erwin brian.erwin7@gmail.com 614-370-7081 |
