Old 01-20-2009, 12:39 AM   #1
RussellinNC
Thumbs up 67 Camaro RS Stocker & 67 Firebird in Statesville,NC
Instead of making several ads Im just makin one so as not to break any forum rules about spaming,etc.
1967 Camaro Real RS,Street/drag car.(Last raced with the Classic Gear Jammers) Clear title,No Engine or trans,(Had a small block and Jerico 4-speed) 4 wheel disc WILWOOD brakes,Braided Brake lines,not narrowed 12-bolt rear with moser axles,spool,4:88 Pro Gear,Braced Aluminum rear end cover,Calvert Rear Split leaf springs and Cal-Trac bars,Frame connectors,Dual holly blue pumps, FRAM filter for each pump,fuel cell,Braided fuel lines front to rear,MSD ignition,Full factory interior with 6 point roll bar,GM cowl hood (I dont have a flat hood for stocker),Small block headers,1 chamber flowmasters,pipes and H pipe,Driveshaft,Rally Wheels,AutoMeter Gauges,Monster tach with Large pro shift light,Etc Etc...Drop in a small block and 4-speed and go play
I have the original Gas tank,Heater box,Heater controls,etc
$10000 FIRM on the Camaro
67 Pontiac Firebird Drag Car, NOT Narrowed,No engine or trans,57 Pontiac rear,Spool,Slapper bars,New 4:10 gear,Weld Wheels,Full cage,Window net,fiberglass front fenders,Hood and bumper,New Lexan MARGUARD windshield,Has clutch pedal if you wanna run a stick,New 90/10 front shocks,solid subframe bushings,frame connectors,quick release steering wheel,Dual Line Locks,No title $5800 obo for the Firebird. You could make this into a Camaro if thats what ya wanted very easy
Ponattack1@aol.com for pics
704-682-3057
Statesville,NC
RussellinNC is offline   Reply With Quote
Search this Thread:
Advanced Search
