I have an 8 inch TCT convertor in my car that needs freshend I think; who do you guys think is the best out there. I have 72 Ford Mustang, 313 nhra rated open chamber cleveland, C-4 with 2.46 low gear, 6.20 gears, convertor currently will flash 6100 but I think I need to be a little looser as my peak power is in the upper 8000 rpm range.
I use Coan for my bracket stuff, talk to Art Reed, but you may want to talk to ATI and compare, they seem to be able maintain great slip percentages even on loose stall converters.
"Despite the high cost of living, it remains popular." Dave Cook NHRA N375 |
Liked 2,023 Times in 607 Posts
Smitty,
I have been running an ATI converter since the early eighties. As a matter of fact that is the converter that I have in the car now. I had it rebuilt by ATI about 3 years ago. I would highly reccomend ATI. I also use some Coan parts in my powerglide. They are very helpful and easy to work with. I think either one could build a good converter for you.
Mike Pearson 2485 SS |
ati
Last edited by Alan Roehrich; 12-18-2008 at 02:17 PM. Reason: it keeps changing my post to all lower case letters |
#5 | |
BTW, I got the trans out Mike, Rebel is going to have it looked at by one of his friends to see what the issue is with it. I figure while it was out I should probably have the convertor looked at. |
Sponsor
Liked 59 Times in 12 Posts
Hi Smitty, I'm Lenny, formerly of TCT. Depending on when you purchased your TCT converter, I probably sold and built it for you. I overhaul and update most brands myself at our new facility.If I can be of any help, feel free to contact me personally.
Ati
Ed Wright 4156 SS/JA |
Smitty,
As I remember the price of the rebuild on my converter was about $350.00. It was an extensive reconfiguration to up the stall speed from about 5400 to 6200. Alot had to be changed. They wont know what they need to do with your converter until they cut it apart and see how it is set up. My converter was an ATI to start with. ATI keeps good records for every converter they build. You can call them with the serial number and they can tell you exactly how it is set up and how it will work with a certian combo. I am sure the other converter companies do the same type of record keeping. I have only used ATI. Jay has a Munsinger in his car. It took him forever to get it back from Munsinger when he sent it for a rebuild. ATI turned mine around in 24 hours.
#9 | |
I'm calling you right now, thanks! |
I like dealing with David Swimm at Atlantic Coast Converters in Conway S.C. They are great to deal with and they will repair any converter or build you one. Family owned and operated.
Michael Smith HR 9063 |
