Old 11-04-2008, 04:23 PM   #1
Anthony Fetch
Default 84 Camaro, 412SBC, 355SBC
1984 Chevy Camaro, crome-moly cage, competition engineering Fab 9 inch, moser spool & axles, 35 spline, 486 gears, nodular center section, aluminum pinion support, ladder bar, hal shocks, koni struts.
Select performance powerglide, trans-brake, 180 straight cut gear set
Rons fuel injection flying toilet on alcohol.
JA Performance SB Chevy 412 CI (less than 65 runs)
Bowtie Block, 14-1 compression, JE pistons, Crower sportsman rods, GM High Performance Chevy Steel Crank, Crower severe duty roller lifters, Comp cams, Brodix track 1 Aluminum heads, Manley Stainless Steel Severe Duty (208-160) Valves, Comp Cams Pak alloy part #955 valve springs, Comp Cams 10degrees Titanium Retainers, 7/16 Rocker Studs, GM High Performance Aluminum Roller Rockers, Stud Girdle.
Went 9.50s on alcohol
JA Performance SB Chevy 355 CI
Dart 2 heads, 12.5-1 compression, manley rods, manley pistons
Went 10.20s on alcohol
Will sell everything separate or will sell the car with either motor
Car is a proven winner. Multiple track champion and multiple high dollar footbrake winner
Call or email Anthony Fetch for more information and prices
973-302-4200
Fetch154@hotmail.com
Anthony Fetch is offline   Reply With Quote
Search this Thread:
Advanced Search
