Old 04-09-2007, 04:54 PM   #1
JCChildress
JCChildress's Avatar
Liked 13 Times in 6 Posts
Default F body suspension advice
We have a couple customers that run F-body cars and cant seem to get them to work very well.
They have QA-1 shocks all around. BMR lower control arms, and spoon mid-mount torque arms, subframe connectors and a cage.
I see a lot of fast stockers really working well. These cars our customers have are making about 600HP. Can someone help me out with some suggestions PLEASE ! Any help would be greatly appreciated.
Thanks,
J.C.
Kowalsky Racing Engines
(434) 821 6107
J.C. Childress
(434) 665-9541
JCChildress is offline   Reply With Quote
Old 04-09-2007, 05:56 PM   #2
Lambertcars
Default
I HAVE A 91 FIREBIRD THAT I AM RUNNING IHRA CRATE MOTOR STOCK,THE CAR WOULD PULL TO THE LEFT ONE TIME THEN IT WOULD PULL TO THE RIGHT IT WAS A HAND FULL BECAUSE YOU NEVER KNEW HOW IT WAS GOING TO LEAVE,THE LEFT FRT TIRE WOULD RAISE UP AND THE RIGHT WOULD NOT,I CALLED JOE RUSSELL AND PURCHACED A SET OF HIS TRACTION BARS AND THAT CURED THE PROMBLEM,THE CAR IS NOW FUN TO DRIVE.I HOPE THIS INFO HELPS
Allen Lambert
Lambertcars is offline   Reply With Quote
Old 04-09-2007, 06:09 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default
Russell's bars are definitly a must to limit housing rotation .... I would also get rid of the short torque arm in favor of a stock length arm. ... Even a reinforced stock unit will work well when used with a crossmember attached to the connectors. Russell can help with that too. Shock settings are really critical if this is a small tire car , too much hit on the tire, and the shock bump setting may not be able to keep the tire hooked up. I have learned that trick suspension parts are not always necessary to put one of these cars on the bumper. ..... Tom
Old 04-09-2007, 09:53 PM   #4
Mtn Mopar
Default
How can you get in touch with Joe Russel ?
Doesnt Al Corda run pretty fast in one of these cars with small tires on it ? How about Woodrow Josey?
I would love contact info for any of these guys....or anyone thats in the know on the suspension for these cars.
Thanks
J.C. Childress
Mtn Mopar is offline   Reply With Quote
Old 04-09-2007, 11:26 PM   #5
Tom Goldman
Default
You can reach Joe Russell@330-484-2960, or 330-268-6374. His parts are basic ,no nonsense stuff. .. I' ve used them on several F-bodies and they work! .. Current B and C/FIA record holder cars have them. .... I think Corda's car is a Wiebe car,also a LS1, Big difference in weight distribution over a LT1 motor. .....Tom
Old 04-10-2007, 08:55 AM   #6
Aaron Allison
Liked 150 Times in 43 Posts
Default
Brand New Traction Bars for F-body Stocker. Built by Joe Russel. Bars are powdercoated and ready to install.
$ 350 OBO
Call Terry Allison at 724 462 6444
Aaron Allison
Super Stock
GTAA
Stock
B/CM
Aaron Allison 395 STK, 395 SS, 3395 SC
Aaron Allison is offline   Reply With Quote
Old 04-11-2007, 09:30 AM   #7
JCChildress
Default
I tried both of those numbers. Never got anyone, but did leave a message.
Any other advice ?
Thnaks for the help so far.
J.C. Childress
(434) 665-9541
Old 04-11-2007, 09:39 AM   #8
SSDiv6
Default
I have also tried both numbers, left messages and even a fax, but no response.
Old 04-11-2007, 10:08 AM   #9
Lambertcars
Default
JOE RUSSELL IS HARD TO REACH BUT IF YOU LEFT A NUMBER HE WILL CALL YOU BACK
Allen Lambert
Old 04-11-2007, 01:15 PM   #10
Aaron Allison
Default
Why not buy a set of already done traction bars. These bars are even powder coated.
Aaron Allison
Super Stock
GTAA
Stock
B/CM
