Old 05-05-2008, 10:40 PM   #1
a2race
a2race's Avatar
Default parts for sale
im posting these for a friend of mine......i don't have pics yet, but soon will. pm me or contact me @ a2race@yahoo.com
thanks,
adam
1. BBC Profiler aluminum 12 degree heads. 415cc castings, not ported. Complete with 2.35/1.88 Victory Titanium valves. Valves have been coated for excessive heat from turbocharged applications and need lapped in. Comes with Erson FSP professional valve springs # E915048 installed at 2.150. This is a 1.677 dia. spring with 346lbs. seat pressure at 2.100 installed height, 1014lbs open pressure @ 1.200. Travel @ .050 before coil bind is .908. Locks are 11/32, 10degree beed locks. Also comes with new Jessel shaft rocker set-up 1.8/1.7 exh. Also have brand new valve covers that are powder coated wrinkle finish black. $4800.00 OBO.
2. Fab Ford 9" housing by ProCar. 1/4 moly 4 link brackets with double row .500 holes with doublers, fully gusseted. .350 faceplate back brace, HD shock crossmember, wheelie bar tabs abd double row bearing ends (symmetrical). 20 1/4" four link centers. Comes with 40 spline, gun drilled axles with double row bearings, wedding rings and 5/8 studs on a 5 X 4 3/4" bolt pattern.width is 43 1/2" from wheel flange to wheel flange. $2800 OBO.
3. Brand new pair of Alumastar 2.0. Also 15 X 15, 5 X 4 3/4 4 lbs. rears with double bead
lock conversion done by Sheppards. Also have 33 X 10.5W MT Slicks with 5 passes. $1800.00 OBO
4. Moroso 5 quart Dry Sump Oil reservoir. $300.00 OBO
5. Griffin Aluminum radiator 18" wide X 22" tall. $200.00 OBO
6. 1991 Chevrolet Camaro cut up for race car. Full cage, entire floor behind the front seat to the rear bumper is cut out. 6" Harwood fiberglass cowl induction hood, fiberglass rear bumper cover with Carbon Fiber wing. T-Top car with new weatherstrip. All apart. will part out or sell as a whole....offer?
a2race is offline   Reply With Quote
Search this Thread:
Advanced Search
