Old 04-18-2008, 10:59 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Correct GT class
What would be the correct GT class for my car? I'm currently running SS/I with the 327/275hp combo with a 207 q-jet. I believe with a 4GC it will be the 250hp combo. Thanks. ED
66 Chevy II
3120 lbs including driver
327 with 4GC carb
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 04-21-2008, 02:15 PM   #2
Bill Harris
Liked 26 Times in 13 Posts
Default Re: Correct GT class
If you have Excel you can use my calculator to tell you what classes you can run. Just enter the shipping weight, factored HP and trans type and it will tell you the legal classes and appropriate weights.
Remember that the rulebook says that for GT classes you have to use the shipping weight for the body style with the largest available gas engine.
www.employees.org/~bhracing/gt_class_calculator_1p1.xls
If you don't have Excel I can run the numbers for you.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 04-21-2008, 04:12 PM   #3
Ed Carpenter
Bill,
I'm not on a computer now with excel. I can do it tommorow when I get home. Do you use the shipping weight of the car your claiming? A 66 never came with the 327/250hp combo. The 65 did. Do it calculate with the 65 car? Thanks.
Ed Carpenter
Old 04-22-2008, 01:14 AM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Ed use the 66 weight.
Old 04-22-2008, 12:08 PM   #5
John Mason
Unhappy Re: Correct GT class
Ed,
You need to change heads as well as the carb to make it a 1963 250 HP. 1.72 intake valve and smaller chamber in the 520 (250 HP) head. Also, it's 250 HP in S/S but 258 HP in GT.
I run GT/IA (12 lb/HP) @ 3266 minimum with that combo.
The 1965 250 HP uses your 275 HP head but it's factored to 260 HP. Maybe the Q-jet is worth the 15 HP. It's got to be close.
John Mason 7743 SS
John Mason is offline   Reply With Quote
Old 04-22-2008, 06:49 PM   #6
John Mason
Talking Re: Correct GT class
That's what I said, but it's factored to 260 HP in SS with the 041 heads or 265 HP using the World heads. I don't think 15 HP less and the bigger intake valve offsets the much smaller carb.
JMHO.
John Mason 7743 SS
