Thread Tools | Search this Thread | Display Modes |
Price drops...I have some parts that I've built up over the years that I decided I'm not going to use. Lots of nice parts. I'm near Denver, CO if you wanted to pick them up. Thanks.
1)... Destroked 400 pistons and Crank combo for 360ci Sprint car class. Set of 8 Brand New J.E. gas ported 2618 forged pistons, 4.125" bore, 6" rod, 3.335" or 3.345" stroke. 14.5cc dome(13.3:1 compression with 64cc chamber or 11.38:1 with 75cc chamber) Complete with moly rings, wrist pins, spirolocks etc. Also have matching forged Winberg crank. 3.345" stroke, Honda rod journals, 350 mains. Freshened up and polished and has no damage. I'm asking $1000 for the combo. 2)... BEAUTIFUL set of two fully refurbished 492 double humps. New EVERYTHING, new stainless 2.02 1.6 valves, new 1.26" springs, retainers, locks, and seals. Complete with screw-in studs and guideplates. Unported. I'm asking $1150. 3)... New set of 8, Dyers Top Rods 300M aircraft quality steel. Brand New and unopened in packaging. 6" rods on a 2" diameter big end. I'm asking $1600 4)... Brand New SINGLE World Sportsman II cylinder head. 64cc chamber, 200cc intake runner, 2.02 1.6 valves. I'm asking $300 5)... Brand New SINGLE World S/R Torquer cylinder head. 64cc chamber, 2.02 1.6 valves. I'm asking $250 6)... Set of 2 462 double humps, used but in good shape. 2.02 1.6 valves. I believe these were in good running condition, however I'd probably go through them and clean them up since the car was sitting for years. They are unported. They would've come on a high HP 327 in Camaro, Nova, or Corvette. 1966 date code. I'm asking $400 7)...283 short block. Bores are good shape and did a hone on them for moly rings in spec at .060 over. Previous rebuild had a deck resurface and it cleaned up well with a brass wheel. Forged crank is 10/10 and in excellent usable shape. Rods were reconditioned in previous rebuild and should be ok. Could also go .080 over or .125 over to build a 302 Chevy since this is an early 1958 block. I'm asking $450. Last edited by 67Nova421; 08-10-2025 at 12:31 PM. |
Liked 53 Times in 6 Posts
private message sent. Thank you. JR
