Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 07-22-2024, 10:37 PM   #1
rt1976
Default Rim Screw Question
Hello
Would like to get some advice on if wheel screws are needed in my application. I?m finishing up a nostalgia drag car and purchased a pair of Bogart Steelie Dan aluminum wheels for the back. I?d prefer not to install screws but want to make sure the car is safe with a stick shift launch.
Race weight is 3,000#
G101a 3.08 1st gear
4.88 rear
Anticipate 1.25 60ft
M/T 29.5x 9 (3056ST) tire
Wondering if sandblasting the bead (they need to be powder coated) , and/or high tack is enough, or if I need to suck it up and drill the wheels.
rt1976 is offline   Reply With Quote
Old 07-23-2024, 05:08 PM   #2
Run to Rund
Liked 54 Times in 27 Posts
Default Re: Rim Screw Question
I have been OK with sandblasting the bead area of steel wheels, and no lube on the tire beads when installing them. I run 4.57 rear, 3.08 Jerico, 1.5 60' for comparison. Car is a few hundred pounds heavier than yours.
Old 08-01-2024, 11:37 AM   #3
Dave Siltman
Dave Siltman's Avatar
Liked 68 Times in 25 Posts
We glue ours to vintage NOS Cragar SS with Permatex Hi-Tack. Messy job but the results are worth it. 1969 W-31, 3700 pounds, 3.08 Jerico, 4.88s. Been plenty of 1.53-.1.55 60’. Same tire 3056ST.
Dave Siltman is offline   Reply With Quote
Old 08-01-2024, 03:51 PM   #4
Jeff Stout
Liked 706 Times in 283 Posts
Glued ours on for demo derby car. Steel and aluminum rims.
Old 08-02-2024, 10:06 AM   #5
Rory McNeil
Liked 1,110 Times in 304 Posts
Will you be running tubeless, or using tubes in the slicks? How high will you be launching, RPMwise? On my bracket car, I am running slick screws, best of 1.29 60 foot, with 2 step low side at 62-6600 RPM. Have ran both Jerico DR4s (3.19 low), and currently a G101A (also 3.19 low), now running a RAM Billet 10"/Black Magic Defiant clutch, but also used McLeod Soft Loks for many years. I am currently using tubes, but mostly ran without tubes until last season. With tubes, I would absolutely run the screws, if the tire moves on the rim enough, it can rip the valve stem off the tube, which is NOT a good thing. On my old 85 Mustang, I ran the 9x29 1/2 3056ST M/T slicks, and did not use tubes, or screws, but that car only went a best of 1.36 60 foots, and mid to low 10s in the 1/4 mile. If you are expecting 1.25 60 foots, that should be well into the mid 9s, I would imagine, if it was me, I would be screwing the tires to the wheels. Huge difference in a mid 1.2 60 foot compared to mid 1.5s.
NHRA 6390 STK
M/S 85 Mustang
Old 09-02-2024, 03:33 PM   #6
Charlie Yannetti
Liked 192 Times in 83 Posts
I bought a set of Weld wheels, and Hoosier recommended that I have the beads knurled to eliminate the use of wheel screws.. works just fine on my SG car.. check into it before drilling..
Charlie Yannetti is offline   Reply With Quote
