Old 07-03-2023, 11:59 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default Chevy LS3, 408 CI drag race engine
New, never started, still on assembly stand. Chevy LS 3 drag race or street/strip engine. *Built with a 6.0 truck iron block.
*Callies 4" stroke crankshaft
*Callies rods
*Diamond forged piston, flat top
*Rotating assembly balance by Callies
*Mahle rings
*Mahle/Clevitte HP rod and main bearings
*Durabond HD cam bearings
*Melling race oil pump
*Cloyes double roller adjustable timing set
*Allstar front cover for use with distributor
*Cam Motion custom hydraulic roller cam
*Johnson race hydraulic roller lifters
*Chevy LS 3 head fully CNC ported
*Brian Tooley race springs per cam
*LS rockers with CHE trunnion and bushing upgrade
*Manton custom length 11/32 pushrods
*ARP studs and bolts
*Polished, tall valve covers
*CID race intake with 4500 Dominator flange
*ATI damper
*LS 3 water pump
NOTE: The engine can be equipped with two different oil pans per your need
NOTE: It also can be equipped to run with EFI setup of your choice
NOTE: It will run on pump 93 octane, E85, race gas, or Methanol.
NOTE: To complete the package to race with a carburetor, you will need, distributor, plug wires, ignition control box, and carburetor.
NOTE: To race with EFI, you will need the EFI system of your choice plus ignition coils.
ID:	67796   Click image for larger version
ID:	67797   Click image for larger version
