Liked 2 Times in 2 Posts
I need help, we have a 68 Camaro bracket car with brodix heads. They have stahl pattern for the header flange. The current headers are shot and the closest replacement header doesn't fit dads budget.
Is there a adapter plate from stahl to oem pattern? Thanks, John Beasaw |
Liked 90 Times in 52 Posts
would the Moroso Header flange kit 67650 not work ?
Liked 83 Times in 24 Posts
I have a pair of Stahl plates,maybe you could use them in reverse?
Text me for a pic 1-613-286-5760 Dom |
Liked 12 Times in 6 Posts
If the Brodix heads are spread port on the two center exhaust ports you can not go to std exhaust flange headers. You can maybe make them fit but the tube to port alignment is way off. Have you checked Schoenfeild headers?
Liked 7,882 Times in 1,753 Posts
Have you called ACP? The old Stahl?
The brodix head may be the bigger issue, i will be looking into that. ACP does offer a header but a bit too pricey.
Thanks! John |
Liked 314 Times in 113 Posts
As DanBar said above, check Schoenfeld Headers. You can order a standard header and specify any bolt pattern flange they have (within Reason). It solved a similar problem I had with a set of heads.
https://www.schoenfeldheaders.com/
Larry Merk |
