Liked 186 Times in 55 Posts
Altronics Red Alert EGT Warning System with down load cable, program and 2 new sensors with weld on bungs used twice and went to data logger. Cost 550.00, sell 350.00 OBO
ARC one cylinder EGT reader with max hold. 55.00 QA1 Rear coil springs 12 Inch. 150 and 130 40.00 per set SBC Bullet Cam with 2-7 swap. 55 mm cam Journals, Gross valve lift Intake -776, Exhaust-690 . 350. OBO SBC Bullet Cam, standard Journals. Gross Valve lift, intake .475, exhaust .456. 200 OBO. Moroso#23690 SBC oil filter adaptor for external pump, ½ npt inlet and outlet 75.00 OBO Comp cams 3/8 inch valve lash caps 16 25.00 Full set Jesel bar bolts, with shims 35.00 8 MGP rods set have 20 runs 5.7 length, 927 pin with Honda rod ends. Arp bolts 300.00 OBO 6 MGP rods with about 80- runs 5.7 length, 927 pin with Honda rod ends, ARP bolts 100.00 OBO Manley Chromoly Swedged end push rods SBC 3/8 16- 7.925, .135 wall, 3706. 150.00 7- 7.775, .080 wall 1013 50.00 8-7.700 .135 wall 4615 90.00 16-7.825 .080 wall 100.000 8-7.650 .135 wall 90.00 Call For More Information Buyer pay shipping Pay Pal Call 203-858-1952 Bob Lasko |
