Old 07-05-2022, 02:33 PM   #1
BobbyH
Liked 62 Times in 19 Posts
Default Fuel tank choice and size for a stocker
Am upgrading my fuel system from a stock tank in my Chevelle.Any advice appreciated.
BobbyH is offline   Reply With Quote
Old 07-05-2022, 03:27 PM   #2
Liked 11,011 Times in 2,263 Posts
Default Re: Fuel tank choice and size for a stocker
Just because it is a AN10 fitting on the tank outlet. Make sure the hole in the fitting is the correct ID size for what ever size the AN fitting is advertised. I had to resize mine.
If you can put your car on a set of scales and move 25 to 30 lbs around to help the balance of the car with the simulated weight of fuel and fuel cell.
I use a five gallon metal tank with foam in it.
Old 07-06-2022, 08:37 AM   #3
Kirk Morgan
Liked 81 Times in 45 Posts
Also put weight in the drivers seat equal to your weight.
Kirk Morgan is offline   Reply With Quote
Old 07-06-2022, 09:36 AM   #4
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
I like the 2.5 gallon ones on Ebay, they have 2 -10 fittings, a return, and a rollover valve. you can get them with and without foam. I know the foam can come apart from certain fuel, I just feel with a -10 return on my car, the foam will de aerate the fuel.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 07-06-2022, 09:46 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
If your car is close on weight use a small cell. I have a 3 gallon cell in my car and usually run 2 gallons in it. I can get real close to minimum weight with a gallon. I have a Jaz plastic cell. No foam. No sense carrying more fuel than needed.
Mike Pearson 2485 SS
Old 07-06-2022, 07:42 PM   #6
Tom O
Liked 151 Times in 36 Posts
I put a Rhodes 4 gal alum. no foam cell in my 68 Chevelle earlier this year. about $175 at Summit.
Tom O is offline   Reply With Quote
Old 07-06-2022, 09:02 AM   #7
J&S Racing
Liked 327 Times in 87 Posts
I really like the simplicity of the Aeromotive stealth set up.
Old 07-18-2022, 06:33 PM   #8
BobbyH
Thanks for all the tips....Blessings BH
Old 07-19-2022, 12:05 PM   #9
B Parker
Liked 2,356 Times in 467 Posts
Take the foam out!!! Bp
