Old 05-04-2022, 10:24 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Team Woodfin's Lamplighter
Team Woodfin’s “lamplighter”
1982 Camaro Superpro, electronics, top bulb bracket racer
Runs 6.0’s 1/8 mile
Weighs about 2750 pounds less driver
Back half four-link, Ed Quay design, built as a Super Stocker
9” rear with Strange axles, spool, 5.29 pro gear.
Strange brakes.
Dart block, 421 CI SBC
Brodix Dragon slayer heads fully worked
Edelbrock intake fully worked
BLP carb, belt drive fuel pump, fuel log with bypass
Methanol fuel
Powerglide with bracket brake and 1.80 straight cut gear set
Ultimate converter
Dayton Sensors DC1 ign system with crank trigger
K & R Pro cube
K & R switch panel, relay panel, wiring
Ed Quay front K member
Vega steering box
Ron G Afterworks struts
Hoosier tires
Good paint but has some bumps from loading and unloading
Power windows
Diaper
Moroso oil pan
Bogart wheels
It also comes with a spare converter, weather station, jacket, helmet, about 20 gals of Methanol, fuel jugs, drum pump, Sunoco drum, and a few other items.
$29,000.00 Can be delivered within a reasonable distance of East Texas
Larry Woodfin 471W
