Old 05-23-2022, 01:11 PM   #1
68Coupe
Default Question about adding weight.
I have a bracket car. was just wonder where is the best place to add weight if you are having a hard time hooking if track conditions are not the best.
Car has ladder bar and coil overs in the back, run a 29x10 slick car is only mini tubbed.
runs 6.40's in the 1/8th.
I have heard various locations.
68Coupe is offline   Reply With Quote
Old 05-23-2022, 02:18 PM   #2
James Perrone
Liked 1,844 Times in 430 Posts
Default Re: Question about adding weight.
Over the rear. If possible or in front or rear
james perrone 1290 STK
Old 05-26-2022, 10:14 PM   #3
Jack McCarthy
Liked 477 Times in 117 Posts
200# spare tire will help
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 05-27-2022, 08:13 AM   #4
Ralph A Powell
Liked 225 Times in 136 Posts
Low just forward of rear axle works well.
Old 05-27-2022, 10:14 AM   #5
68Coupe
So in the trunk over the rear end would be better than as far back and as high in trunk
Old 05-27-2022, 10:39 AM   #6
Jeff Stout
Liked 706 Times in 283 Posts
Check out Kevin Wilson on YouTube. 1 of his videos talks about where and what weight placement does to a car. Very informative. Also he talks about shocks, 4 link, ladder bar set up for all kinds of racing.
Old 05-27-2022, 11:04 AM   #7
SSDiv6
There are lots of parameters to be considered such as the weight of the vehicle, wheelbase, class, type of suspension, horsepower, and other factors.
After spending time scaling different cars for Stock, Super Stock, Comp Eliminator, Top Sportsman, and other classes putting the weight forward of the rear end is the best compromise and maintaining 52% to 54% of the weight in the nose.
Old 05-30-2022, 07:59 PM   #8
Liked 10,838 Times in 2,253 Posts
How many of them had a four link.
Old 05-31-2022, 09:46 AM   #9
SSDiv6
All the Comp cars, and some of the Super Stockers had 4-Link.
The Stockers, and some of the Super Stockers had Calvert suspension.
Have never touched a ladder bar car.
Old 06-01-2022, 10:03 AM   #10
Charles Stewart
Liked 755 Times in 213 Posts
You can add a certain Stock class section on your list: Factory Stock.
Upper control arms are adjustable (heim joints). Upper control arms brackets at the frame have 2 positions to add tuning. Lower control arms have bushed ends and only one hole on both brackets (frame and housing). But, I don’t see any rules regarding the holes position on those, neither rules regarding certain dimensions for those brackets. Also, I don’t see any rules regarding the length of those control arms.
Charles Stewart is offline   Reply With Quote
