Old 06-28-2022, 12:40 AM   #1
tgallagher
Liked 3 Times in 2 Posts
Default o/t hot water heater fix?
I changed the thermo-coupling-copper wire
still got nothing...pilot will not stay lit,------, going thru the switches now,
i know its off topic, just throwing it out there. Pilot will not stay lit!
tgallagher is offline   Reply With Quote
Old 06-28-2022, 02:19 AM   #2
tgallagher
Default Re: o/t hot water heater fix?
-I take pride in saying "You will never see a contractor at my house"...
Yes, that is true---now, here, the one time we had a plumber come around-a few months back--turns out---He was fixing to get to the 4-wides in NC, what a cool guy. He was telling me about his El dorado he got carried away with modifying it---we got talking so much---
so i give him a call 2 morrow--I'll let you know how it turns out.
thanks for listening.
Old 06-28-2022, 05:02 PM   #3
tgallagher
Thumbs up Re: o/t hot water heater fix?
ok- was micro switch hidden on top of the hot water heater, behind a couple of wire nut things-- I had overlooked. There is one at the bottom and one at the top.
He said it was a bit too hot up there possibly because the draft was getting slowed down a bit, and that may have triggered it to pop--
I looked down chimney cleaned it out a bit, but no substantive result other than he recommended a CO2 alarm just in case.
I had no idea this section was here; otherwise I would have posted it in here originally! This is definitely where it belongs, -now I know.
Thanks all!
