Liked 361 Times in 81 Posts
Have you stick guys made an access panel for clutch adjustment? What have you done. Thanks
Banned
Liked 179 Times in 89 Posts
You can drill a 1in hole in the face of the bell to access the adjusters but you will have to slide the tranny back to adjust the pressure plate.
I believe the only way to have a removable panel will be to buy a bell with the removable panel that is SFI certified. |
Liked 173 Times in 52 Posts
I sent mine to the Manufacturer for a window, Quicktime in my case. Chevy 55 is right it has to be re-certified after any modifications are performed.
Kelly Lane Stk4991 |
Liked 125 Times in 33 Posts
Agree with the previous responses, and would add that Browell makes an excellent bellhousing. They will customize to meet customers' needs including SFI compliant window to ease counterweight adjustment and hole through the back for quick adjuster changes.
Liked 1,144 Times in 354 Posts
I wanted to buy a Browell, 12 months later still waiting. I bought McCloud, a few hundred dollars cheaper, lighter and adjustable friendly for clutch and air gap.
Liked 275 Times in 76 Posts
The Browell bellhousing was probably one of the best purchases I have made. As Mr. Ames pointed out, you can have the window clocked anywhere. The hole for air gap measurement they will drill and tap it for a plug. The other added benefit, alignment was spot on with 2 different engines. You get what you pay for.
427FE, If you are wanting to modify the bellhousing yourself, its been done. Others will tell you "Tech has never looked at my bellhousing certification date so have at it with modifications". That is up to you. For those with bellhousings without a window, its not uncommon that they drill a hole so a long allen socket will reach the adjuster. CW is a different can of worms. I fabricated offset wrenches and would put duct tape on the wrench to capture the hardware and reach through the fork window. It was a fishing expedition when I dropped aluminum nuts or bolts! There are pictures and how people with fabrication skills added a window to their bellhousings on the internet. Sean
I wanted to buy a browell, but they couldn't accommodate a 184 tooth flywheel, didnt want to go down the custom starter route. Thanks for replies.
Liked 804 Times in 168 Posts
I had a non window Quiktyme and it needed to be re certed , they recerted it and put a window in it very reasonably. They also told me that the window bells for stock are now a 5 year recert, previously a 2 year
Dave Casey 1330 STK |
Liked 166 Times in 54 Posts
When was this, I had mine recertified and was told 2 yrs since the window is in it?
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Also quicktime wanted $500 extra for the window
