Old 11-11-2022, 11:24 AM   #1
davidhuff
Liked 120 Times in 42 Posts
Default 2001 Camaro SS with 12,405 Original Miles
2001 Camaro SS Hardtop, Rust Free,Original Paint and in Mint Condition(481 HP 498 Torque on DYNO SHEET)
FUN FAST STREET CAR WITH AC( Only made 56 Red Camaro SS Hardtops with a Six Speed)
MOTOR:ERL Performance 427C.I.Dry Sleeve LS3 Block.Callies Compstar H Beam Rods,Callies Compstar Forged Crank,Wiseco Pistons 11.5 to 1,LS3 Intake,95MM Holley Throttle Body,60# Injectors,American Stainless Headers with high flow cats and ARP Fasteners through out motor,
Final Invoice on motor from Norris MotorSports was $22,596.35 with only 3,000 miles since build and can send {Build and Dyno Sheets} if interested.
HEADS:Landspeed Develoment CNC Ported LS3 Ported Heads
TRANSMISSION:Factory T56 Six Speed with Factory Installed Hurst Shifter
CLUTCH:Monster Twin Disc /Flywheel Kit with a Tick Performance Quick Clutch Bleeder Valve
REAR END:Qiuck Performance F Body Nine Inch Housing mounted in factory stock location,4.11 Ratio with a Eaton Truetrac and Moser 31 spline axles
Rear Suspension:UMI Torque Arm Kit,UMI Lower Control Arms and UMI Adjustable Pan Arm Bar
Price:$29,500
NEW PRICE:$25,900
David Huff
sgthuff@hotmail.com
503-930-3045
ID:	65569   Click image for larger version
ID:	65570   Click image for larger version
ID:	65572   Click image for larger version
ID:	65573   Click image for larger version
ID:	65575   Click image for larger version
