Old 01-27-2022, 11:58 PM   #1
BobbyA312
Default Past NHRA national Results
Are the results from the 60's and 70's national events archived in a location online where stock class wins could be viewed? Thanks in advance.
BobbyA312 is offline   Reply With Quote
Old 01-28-2022, 10:43 PM   #2
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
Default Re: Past NHRA national Results
If there is, I certainly haven't found it.
The best source I've found is the "Nostalgia Stock & Super Stock" section here. Results are scattered. No particular order whatsoever.
Sometimes you'll find class winners, sometimes entry lists, sometimes nat record holders, sometimes event winners.
I suppose if you have LOTS of time & are very patient, you could go thru & pick out all the info of interest to you & compile it into some sort of order, so that you could find it quickly, if you wanted to. Would be quite a project.
Old 01-30-2022, 08:30 PM   #3
Mike Schwartz
Liked 252 Times in 91 Posts
Post Re: Past NHRA national Results
I found a page that lists all the NHRA National Event winners. NHRA published a similar list but I can't locate the current URL. I'm not aware of a single source for class winners.
Old 01-31-2022, 02:44 PM   #4
oldskool
oldskool's Avatar
http://www.nhra.net/50th/resultslist.html
Tom Kasch has the largest collection of class winners that I know of. Class winner lists are scattered. But if you have enuff time & patience, you can probably gather up quite a few class winners.
http://classracer.com/classforum/showthread.php?t=75995
Old 01-31-2022, 08:29 PM   #5
BG56
Liked 301 Times in 113 Posts
Nice!
