Liked 186 Times in 55 Posts
SBC 23 Degree Jesel Pro Aluminum Series Shaft Rockers. 1.5-and 1.6 ratios. .250 offset on the intake and Zero on the exhaust. Standard slot. See description from Jesel, link https://www.jesel.com/pro-aluminum-series-shaft-rockers
This is a complete set with steels stands, bolts for stands, bolts for rockers and shims. These are the rockers that only can be brought through your machine shop. 800.00 OBO two sets of QA-1 12 inch length coil springs, 150 and 130. 45.00 each. SBC Bullet Cam with 2-7 swap. 55 mm cam Journals, Gross valve lift Intake -776, Exhaust-690 . 400. OBO SBC Bullet Cam, standard Journals. Gross Valve lift, intake .475, exhaust .456. 300 OBO. Moroso on head spring tester 0-300 50.00 OBO Moroso on head spring tester 160-400 100.00 OBO Manley push rods SBC 3/8 : 16- 7.925, .135 wall, 3706. 125.00 7- 7.775, .080 wall 1013 50.00 8-7.700 .135 wall 4615 90.00 6-7.825 .080 wall 4107 40.00 8-7.650 .135 wall 3716 90.00 Buyer pays shipping Pictures on request Call 203-858-1952 Bob Lasko lasko@oiptonline.net Last edited by Bob Lasko; 01-13-2022 at 12:38 PM. |
