Old 03-25-2021, 08:21 AM   #1
e vassar
Liked 272 Times in 108 Posts
Default F.I. fuel pressure theories
36lb injectors at 50 psi or 42lb injectors at 40 psi . If I am able to achieve an optimal A/F either way...which will produce more power and greater consistency? Either? My theory is the higher pressure going through the smaller orifice will produce a finer mist..or better atomization which is always better? Or not?
