Old 09-02-2007, 09:30 PM   #1
Larry Ingram
Talking Ford 302 Stocker Parts
This list is a balanced assembly and I have balance sheet:
1.New 302 crank with cryo work done 350.00
1.New #870007 TCI Rattler Balancer 225.00
1.Used Crower Sportsman Rods 200.00
1.87-95 Venolia Stocker 4.030 Pistons and Pins 450.00
1.New #529618 TCI Automatic Flywheel 65.00
I have marked this assy. done to 1290.00, but will take 1150.00 and you pay the freight
2. Motorsports Sportsman block. Bought as a shortblock then
dis-assembled to use for this. It is std. bore. 600.00
3. 1 pr. E7TE stocker heads fresh done and no skunk work
prepared by Wesley Roberson 450.00
4. New #16100 Canton Fox Body Pan w/windage tray and
ARP bolts 200.00
5. New Ford Motorsports Hyd. Roller Lifters worked by
Allen Sherman 200.00
6. New #8138 Comp. Cams Roller Timing chain assy. 100.00
7. New Bullet roller billet camshaft 150.00
8. New Alum. Timing Cover 40.00
9. New Edlebrock Air-gap Performer manifold 200.00
10. Used 302 MSD #8582 Dist. 125.00
11. New #8455 MSD dist 94-95 Electronic 240.00
12. Used MSD #7210 7-A ignition box 100.00
13. New Tall Plain Polished Valve Covers 25.00
14. New Polished Electric Water Pump 100.00
15. New ARP Head Bolts 25.00
16. New #4505 Comp Cams 3/8 Rocker Studs 30.00
17. Used BG280 fuel pump w/brackets 100.00
18. New #13301 Aeromotive by-pass regulator 100.00
19. New TCI 8" convertor ssn/CSSX-5 call Gary Bruce@ TCI
for info 350.00
20. New #616332 TCI Outlaw shifter 180.00
21. New 15x4 Weld ProStars, mounted never ran 250.00
I have Listed these items seperate from upper, whole package is 4855.00
and can be bought for 4650.00. You pay freight
I am getting out of racing, I have no time to travel and not interested in bracket
racing. 601-942-3131 after 6:30 pm eastern or e-mail racingfrog56@aol.com
Larry Ingram is offline   Reply With Quote
Old 09-17-2007, 06:29 PM   #2
Larry Ingram
Default Re: Ford 302 Stocker Parts
Make any resonable offer, Items have to go, Thanks
Old 09-21-2007, 10:23 PM   #3
partsbob67
Liked 79 Times in 11 Posts
larry you have a pm.
partsbob67 is offline   Reply With Quote
Old 09-21-2007, 11:09 PM   #4
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Larry, I also sent you a pm because your email doesnt work
1347 is offline   Reply With Quote
Old 11-14-2007, 08:04 PM   #5
Larry Ingram
Cool Re: Ford 302 Stocker Parts
Looking for a stock 4150 base carb intake for 1985 Mustang 5.0
Also, Upper and Lower intake and Throttle body for 1989 Mustang 5.0
Old 11-14-2007, 08:06 PM   #6
Larry Ingram
Lightbulb Re: Ford 302 Stocker Parts
These parts have a deposit on them as of now, will repost if deal falls through. Thanks for looking
