Liked 59 Times in 13 Posts
- DRC Race Products, P/N 1010 Valve Spring Removal Tool for small block chevy, brand new, used once and did not work on our short deck motors, comes with 3’ and 2’ long handles, $75
- Wedge Tri-Y headers, 1 ¾” – 1 7/8”, with 8 EGT and 8 oxygen sensor bungs, off Eastexas Cavalier, $1,500 - (2) Stroud Window Nets, angled for EastTexas Cavalier, uncertified, $25 - Pit Pal Ez-lift jack holder, Part #196, new $290, sell for $150 - Bickel 4 guage panel, new, part #JB-027B, $15 - Bickel bearing collar part #JBRC5720, threaded for sensor, new $75 - Bickel bearing collar part #JB5721, threaded for sensor, used $50 - Bickel bearing collar part #JB5721, threaded for sensor, new $75 - 12 degree 615x GM heads complete - updated by Slawko in 2019, HRE intake manifold with single and dual tops built in 2019, Jesel rocker arms, Diamond pistons with less than 30 runs, used on 316 motor in D/SMA, will work perfect for Super Stock modified, $8,500 (contact Don Thomas at PPE with questions – 806-382-3244) - Stef’s oil overflow tank, -12inlet, $50 - Camico RV A/C vinyl cover for Coleman Mach II, II, III, #43591 (new in box) $20 - Victory Titanium valves, used, 5.55 OAL, ran in Slawko heads, $250 - GRP aluminum rods, part #69559, approximately 60 runs, $250 - BME pistons from 316SBC, 4.060 bore with pins, approx. 60 runs, $300 - HRE intake manifold, used with CFE 10 degree heads, single and dual tops, $600 - Hogan Sheet Metal intake manifold, made for 8.290 deck height aurora block, used with Slawko heads, dual and single tops, used, $400 - Patterson 4 hole carb spacer, 4150, $125 - JAZ fuel cell cap assembly, new, $35 - JBRC 20” lug nut socket 15/16”, $50 - Reactor 153 tooth flexplate, expired, $100 - Central Machinery pipe/tube notcher #42324, $35 - LAT motor oil, Pro 15wt break in oil, 6 gallons, $270 - Koni double adjustable rear shocks off 05 Easttexas Cavalier with EIbach 140pd springs, $400 - CSR transmission/flexplate super shield, P/N 826, expired $125 - Moroso oil restrictor kit, new in package, #2200, $10 Buyer pays shipping. Contact Michael.compton@sbcglobal.net or 417-437-1669 with questions. Last edited by Michael Compton; 12-01-2020 at 11:25 AM. Reason: Items sold |
