Old 11-09-2020, 12:09 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Quay 4 link, with or without anti-roll?
My 3rd gen Camaro Lamplighter project is equipped with an Ed Quay, unequal length, four-link system, and rear frame. It is a back half build the OE front suspension and Randy Mans front struts.
The question, up to recently adding an anti-roll rear bar, has been the standard thinking. However, there has been some suggestion that the unequal length bars work better without the anti-roll.
For those racing with the Ed Quay back half, what is your feedback about the anti-roll bar?
Larry Woodfin 471W
Old 11-09-2020, 01:25 PM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: Quay 4 link, with or without anti-roll?
My Monte was built by Ed in 1985 and my experience was the opposite. It was an unequal 4 link. I struggled to get car from not rolling over. With anti bar it solved roll over, but cant say it was faster.
Jeff Stout is online now   Reply With Quote
Old 11-09-2020, 02:26 PM   #3
tylerw5089
Liked 31 Times in 7 Posts
My car is a Quay car and I had an anti-roll installed to stop the body from rolling so bad. I have had zero issues with mine.
tylerw5089 is offline   Reply With Quote
Old 11-09-2020, 03:02 PM   #4
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Do you have access to scales?
My first GT car was a Quay car.
I was able to correct that tendency w/o a anti-roll system with more preload in the right top bar and a little extra height (3/4") on the driver side front spring.
That being said - there's nothing wrong with an anti-roll system.
Also - downward (nose down) rake on both bars (top and bottom) helps to limit the amount of roll.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 11-09-2020, 06:20 PM   #5
Jeff Stout
I would lengthen top right rear and had 120lb additional on left front. The car was very crooked looking. My bottom bar was 3 degrees down and top bar was 17 degrees down. Once anti was in I was able to make right upper bar neutral with only free play removed.
Old 11-10-2020, 11:25 AM   #6
curtis reed
Liked 125 Times in 59 Posts
Larry this may seem crazy to you but it really helped mine. Once I got to 5.60s it was a hand full. Just an option to keep in mind.
curtis reed is offline   Reply With Quote
Old 11-10-2020, 11:32 AM   #7
Dragsinger
Curtis, I like that, a good idea and easily done. Do you also employ an anti-roll bar?
Larry Woodfin 471W
Old 11-10-2020, 01:19 PM   #8
bert powell
Liked 34 Times in 12 Posts
I have built two of these cars and have not had problems with body roll, not sure if it is how they were setup or lack of power, lol.
I worked with Ed 20 years ago and he provided details on the setup that are still in my car today. My car is setup neutral- no squat and no separation. I have some preload in top passenger bar but minimal. Bottom bar is 2 degrees down, cannot remember top bar location. I scale car with 40# more on driver rear than passenger rear. Front is same side to side. I did have driver front springs 1/2 coil higher initially but went to Santuff springs which are equal. Never saw a difference in roll.
In my humble opinion- if the shocks are set soft, rear springs are soft or 4 link is set for excessive squat- you could have the body roll.
It appears some cars require anti roll bar and some do not, everybody has a different recipe.
bert powell is offline   Reply With Quote
Old 11-10-2020, 01:24 PM   #9
Dragsinger
Bert, Thanks, I appreciate the note.
Larry Woodfin 471W
Old 11-10-2020, 04:31 PM   #10
curtis reed
I don't need it because this acts as it's own ARB.
