Liked 302 Times in 73 Posts
Has any one done any type of testing to figure out the performance changes in a SBF that has been neutral balanced vs the stock 28 or 50 oz balance.. is it worth enough to spend the money on the Mallory or is it so minimal that it'd only be worth trying if you wanted to be #1 at Indy...
Brad |
#2 | |
Liked 166 Times in 54 Posts
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Liked 36 Times in 26 Posts
I believe the newer cranks like eagle are manufactured for 0 balance, so they don't require mallory. Last two cranks I had done required lightening, no mallory
[QUOTE=HawkBrosMav;628249]Is this from a performance improvement stand point or just bearing life and overall dependability of the engine's life? Is it actually worth HP?[/QUOTE
Dependability and reliability ....cracked blocks are not good
you can get the eagle and scat in 0 or 28
#7 | |
[QUOTE=Stephen & Horace Johnson;628251]
Additional info; were making 300-350 HP tops... not a speed demon by any means haha Brad Last edited by HawkBrosMav; 11-18-2020 at 02:41 PM. |
I had a few Boss 302 cranks I ran for years, and then I broke a crank, caught it in time. But the metallurgy has changed, So I ran this Boss 302 crank for a long time came to rebuild with rods and pistons, and I opted for a new crank. The cranks wear out. I felt better with a new crank that was made for neutral balance, that one that had seen service since it was made
Go neutral balance and get the crankshaft from Molnar Technologies. Every time I use Eagle or Scat, it requires work to correct issues.
Liked 240 Times in 112 Posts
I've got a 28oz cast crank 351c that goes to 7300. It's been together 7 years and didn't get twisted that high till I figured some things out. I had a local machine shop balance it and it feels smooth @ rpm. The external balance gives a tiche less iron flying around Inside the crankcase.
I've also got a recently acquired Molnar massaged crank for my good engine. That's going to be a while though, too many projects.
Dave Noll, EF/S ,?/SA 6526 |
