Liked 120 Times in 42 Posts
I know very little about Density Altitude and was searching for information.
Liked 4 Times in 2 Posts
Liked 240 Times in 112 Posts
My understanding that 1 and 2 barrels swing wider than 4 barrels and low compression wider than high compression and a stock converter (sportsman bracket) wider than a high flash converter, etc, etc, etc, etc . The really good cars may change very little with the weather.
Dave Noll, EF/S ,?/SA 6526 Last edited by Dave Noll; 12-12-2019 at 05:47 PM. |
Liked 3,227 Times in 981 Posts
While I’ve always referenced Biondo’s tips as a guide I would just point out that meticulously keeping notes on all your runs is invaluable to setting up a reliable correlation curve between DA and ET since the host of other variables (i.e. wind) can play such a huge role. I’m just now trying to explore some of the analytics of this and discover that my last year’s record keeping was painfully inadequate. You can probably guess one of my New Year’s resolutions.
Liked 226 Times in 137 Posts
Percent of oxygen changes can have a big impact and since very few measure this the basic numbers can remain the same but the percentage of oxygen can change and have a large impact!
On my two cars basically 200 feet of altitude change equals one hundred .01 I run them a little fat so that it will be this way
Liked 706 Times in 283 Posts
That's pretty good. Im 145ft of change and. 1 ET difference. I run mine just right in the heat then when air gets good car goes lean. That gets me the 145ft average
Liked 62 Times in 29 Posts
Liked 13 Times in 7 Posts
My experience has been that if you run around the ideal air/fuel ratio you will see 150 ft equals .01. Or you can run lean and move higher into the 200ft area. It gets hairy as you get leaner and can do engine damage. The only time that I've seen the 300ft range is with ethanol in our bracket car. A normal ethanol car will equal the 300ft per .01 area. If you don't see these numbers or if your car isn't consistent , you probably have a problem that needs correcting.
Richard Grant 4988 STK |
Liked 223 Times in 73 Posts
I've been strongly suspecting for a while that this is the case. When I stay near home I can get a pretty good idea from DA and wind but then I go to a different area, where they have those weird tall things (I think they call them trees) and suddenly I'm way off in my dial-in.
