Old 06-10-2019, 09:36 AM   #1
burton5809
Liked 26 Times in 2 Posts
Default Cracked front wheels
I just wanted to make everyone aware of an issue I had late last week. I was cleaning the race car and had removed the front wheels to clean them and found small cracks near the hub of the wheel on the inside. Each wheel had these all in the same location. I know other racers have had issues with front wheels before but just a friendly reminder to look them over. This could of been costly if I had not found this. These were black anodized Weld Alumastar wheels that I have had for 7 years.
Brad Burton
Name:	cracked wheel 1.jpg
ID:	50291   Click image for larger version
Name:	Cracked wheel 2.jpg
burton5809 is offline   Reply With Quote
Old 06-10-2019, 09:44 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Cracked front wheels
Inspect your wheels regularly as all these lightweight, front billet wheels crack regardless of manufacturer, some rear wheels too. If you're lucky, you find the crack before it fails and you crash as some have. I've had 2 pairs of Weld Magnum wheels crack, one wheel broke and exited the wheel well as I was tuning into my pit spot after just having made a pass. I know racers that have also had V series crack as well.
Old 06-10-2019, 10:03 AM   #3
Jim Kaekel
Liked 536 Times in 110 Posts
Thanks for sharing, Brad. It serves as a reminder to keep a keen eye on them.
Jim Kaekel 3836 STK
Old 06-10-2019, 11:28 AM   #4
Dave Casey
Liked 804 Times in 168 Posts
Thanks, I will be checking mine this week, good pics showing the cracks too
Dave Casey 1330 STK
Old 06-10-2019, 12:05 PM   #5
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
If you have Bogart fly's with the black back plate,check them often bad for cracking!. gsa612
Old 06-10-2019, 02:47 PM   #6
CMcAllister
Liked 929 Times in 263 Posts
Do the manufacturers give any help or do they just go in the scrap barrel and you replace them with a new set? How much does the weight of the car enter in to this? Same problem occurring on any lightweight (<2600#) cars?
Old 06-10-2019, 03:00 PM   #7
1320racer
1320racer's Avatar
Weld did nothing, told me their wheels have a 30 day warranty for manufacturer defects. Which means they have no real warranty. I replaced the broken/crack wheels with the same Magnum wheels but this set is black anodized.
Old 06-10-2019, 04:33 PM   #8
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
Anybody experience cracks with Weld Pro Stars?
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 06-10-2019, 05:14 PM   #9
Mark Callanan
Liked 64 Times in 14 Posts
We did last fall
One was leaking air is how we found it
Better that way then on the track
Both fronts were cracked
They were 17 years old so wasn't surprised.....
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 06-10-2019, 06:10 PM   #10
SSDiv6
There are a lot of factors that will effect the longevity of drag racing wheels such as wheelstands, car weight, design of the wheel, material, fatigue and more.
The enclosed link, although it applies to non-wheelstanding cars, talks about the subject:
http://www.mcculloughpr.com/media_fi...Car_June16.pdf
