Old 09-26-2007, 11:15 AM   #1
RJ Sledge
Liked 294 Times in 93 Posts
Default Rv 455?
Does this stuff really work, and how do I get it? Thanks RJ
RJ Sledge is offline   Reply With Quote
Old 09-26-2007, 11:26 AM   #2
TS310C
Default Re: Rv 455?
It works awesome. Spray on, wipe off and rinse. The black streaks just melt away! I ordered mine from the website www.rv455.net
TS310C is offline   Reply With Quote
Old 09-26-2007, 11:50 AM   #3
RJ Sledge
Default Re: Rv 455?
Ordered a couple of gallons, thanks for the info.
RJ
Old 09-26-2007, 11:55 AM   #4
7820
7820's Avatar
Default Re: Rv 455?
RV455 is great stuff. Works just as everyone says it does. Spary on....wipe off....clean trailer, RV, garage doors, floor of trailer, etc, etc, etc.
7820 is offline   Reply With Quote
Old 09-26-2007, 01:18 PM   #5
Talking Re: Rv 455?
RJ---455 is the greatest thing since sliced bread--talk about easy--this is it.You can buy it from my fellow D1 racer-- (and longtime friend) -Dave Riberio--he can be reached at 757 810-1832--he'll be glad to ship you some.
Old 09-26-2007, 03:53 PM   #6
RIBEIRO RACING
Guest
Posts: n/a
Thumbs up Re: Rv 455?
Hey Jack,
Thanks for the kind words, RJ this product will clean just about anything you can think of.....
As the other racers said, simple to use ,just spray on and let set for 10-12 seconds, then wipe with a dry towel, rinse with water and wipe again an all the streaks and dirt are gone...This doesn't hurt paint or decals and one gallon will do two 34' Trailers, RV's Boats..For best results do this in the shade... RJ, when you try this product you will wonder why you didn't use it sooner....Thanks, for trying RV-455 , contact me if you have any questions..........
Dave...1033/stock(350ci)
Old 09-26-2007, 03:59 PM   #7
Chip THELEGEND Johnson
Liked 283 Times in 80 Posts
Default Re: Rv 455?
Dave,
If you're coming to MIR bring me a couple gallons.
Chip
Chip THELEGEND Johnson is offline   Reply With Quote
Old 09-26-2007, 04:25 PM   #8
RIBEIRO RACING
Guest
Posts: n/a
Wink Re: Rv 455?
Chip,
I will be bring a extra couple of cases of product... Yes, I already have 2 saved for yah...
See you there and drive safe.................Dave...1033/stock(350ci)
Old 09-26-2007, 04:53 PM   #9
76 RACER
Default Re: Rv 455?
As the former owner of the company you will find nothing better on the market today that will clean your trailer and make it look the way you expect it should! Best results are obtained by using the product above 70 degrees. The heat from the sun will open the poors in paint,gelcoat and fiberglass or any other surface you want to clean. This will let the RV-455 penetrate the surface to be cleaned. Its that simple. I suggest using the white Terry Cloth rags you can buy at all automotive parts stores. RV-455 works great on airplanes,Motorhomes,trailers and is great for oxidized paint on a car. Please dont be fooled by other imitation products! Just dont let your wife know you have it because it will disappear as she will be using it! Thanks to all the customers that use and believe in RV-455..... Gary Densham told me that it is the only Product he had found that works as advertised!
76 RACER is offline   Reply With Quote
Old 09-26-2007, 06:34 PM   #10
Mickey Whaley
Default Re: Rv 455?
How much is a gallon?
Mickey Whaley is offline   Reply With Quote
